uxer
Is Wiki correct on "Use SSH to execute commands"?
Wed Jul 06, 2022 7:33 pm
MikroTik firmware version is 6.48.6 (long-term)
Trying to achieve passwordless access via ssh, following the 3 steps from https://wiki.mikrotik.com/wiki/Use_SSH_ ... o_RouterOS
First I tried with a dedicated user, failed, tried with default admin, failed. Here for simplicity lets talk about admin.
Issues:
  • Can't access
    ssh -i ~/.ssh/to_MikroTik admin@192.168.88.1
    passwordless having installed "to_MikroTik.pub" key;
  • Can't access
    ssh admin@192.168.88.1
    with password - "Permission denied, please try again.". I copy password from a password manager, no typos, but ssh doesn't let me in, whereas I can access via webfig, delete ssh key at
    System -> Users -> SSH Keys
    and then I can again
    with password
Commands:
ssh-keygen -t rsa -m PEM -f ~/.ssh/to_MikroTik
http://man.openbsd.org/ssh-keygen says uppercase "PEM", not lowercase "pem" as MikroTik Wiki says.
Double Enter for empty passphrase.
cd ~/.ssh/
ftp 192.168.88.1
put to_MikroTik.pub
^D
user ssh-keys import public-key-file=to_MikroTik.pub
^D
Wiki has it:
user: admin-ssh
it looks like a prompt is to be displayed, I get nothing like this, even with another user pre-created.
If I understand it right, I should be able to passwordlessly ssh into MikroTik with:
or passwordlessly execute commands e.g. see leases with:
ssh -i ~/.ssh/to_MikroTik admin@192.168.88.1 ip dhcp-server lease print
but it doesn't happen.
So, what is the way to make it happen?
Also, Wiki:
3) Now from either Winbox or terminal mode you need to import the key.
Why webfig isn't mentioned?
mkx
Re: Is Wiki correct on "Use SSH to execute commands"?
Wed Jul 06, 2022 9:48 pm
Can't access
After you import SSH key, default setting is that logins with password for that user are disabled. You can enable it (so you have both passwordless and with password) by executing
/ip ssh set always-allow-password-login=yes
I don't know why your public key doesn't work. I just tried (my router runs 6.49.6 but I dont think it should make any difference) by executing this sequence of commands:
ssh-keygen -t rsa -f toMikrotik
# double enter
scp toMikrotik.pub <privileged-user>@<router>:
ssh <privileged-user>@<router>
/user ssh-keys import user=<non-privileged-user> public-key-file=toMikrotik.pub
/quit
ssh -i toMikrotik <non-privileged-user>@<router>
# got logged in without typing password
I'm using debian buster which comes with openssh-client version 7.9p1 ... and ssh-keygen creates public key file in format accepted by ROS without any additional maprameter (i.e. -m).
Note that I used scp to transfer the file to router instead of ftp, this might (or might not) make a change.
uxer
Re: Is Wiki correct on "Use SSH to execute commands"?  [SOLVED]
Thu Jul 07, 2022 5:12 pm
Solved.
viewtopic.php?p=931991
cat ~/.ssh/config
Match host 192.168.88.1
  PubkeyAcceptedAlgorithms +ssh-rsa
Now it works.
And no `-m PEM` is needed on OpenBSD, even though http://man.openbsd.org/ssh-keygen#m says:
By default OpenSSH will write newly-generated private keys in its own format
and https://wiki.mikrotik.com/wiki/Use_SSH_ ... o_RouterOS says:
Warning: If ssh-keygen generates key in openssh format, then add "-m pem" to generate key in PEM format, otherwise you will not be able to import it in ROS!
They may have meant public key, not private one, but they don't clarify it.
@mkx thanks for your reply and clarifying disabled password access when key has been added. Even though ssh with -v still says:
debug1: Authentications that can continue: publickey,password
Confusing, IMHO
In some projects, devs and maintainers monitor project forum and fix the code and docs when issues arise. Do MikroTik devs do so?
The solution was posted almost 2 months ago viewtopic.php?p=931991#p932048 with no impact on the docs.
I have filed a ticket to the support asking to add
to the Wiki (and https://help.mikrotik.com/docs/display/ROS/SSH).
Users browsing this forum: Yahoo [Bot] and 193 guests
