I'm pretty new to Mikrotik and RouterOS. I have a very simple setup. Almost the default config that comes with RouterOS7 on a hEX Lite.
I've a single IP address range `10.30.0.1/24` assigned to the bridge that bridges across all the LAN interfaces (ether2-5).
Code: Select all
add auto-mac=no comment=defconf name=bridge
add name=dhcp-pool ranges=10.30.0.21-10.30.0.254
add address-pool=dhcp-pool interface=bridge name=dhcp-pool
add address=10.30.0.1/24 comment="Office Network" interface=bridge network=10.30.0.0
I understand these requirements are esoteric and break many best practices for setting up networks. Is it possible to configure the hEX Lite/RouterOS to enable this? I tried setting up static routes and firewall rules, but I wasn't able to get anything to work.
