Wublide
need help with script syntax
Fri Jul 08, 2022 4:21 pm
I need to find what's wrong with this code:
:do {
    :local checkdns [:resolve "my.dns.domain" server=x.y.z.x]
        :if ([/ip dhcp-server network get value-name=dns-server number=0] !="x.y.z.x" or
             [/ip dhcp-server network get value-name=dns-server number=2] !="x.y.z.x") do={
		SOMETHING
} on-error={
	SOMETHING ELSE
What I want to achieve is: if my.dns.domain resolves though server x.y.z.x then check if network number 0 and 2 do not have x.y.z.x as current dns server then do something
2frogs
Forum Veteran
Forum Veteran
Re: need help with script syntax
Fri Jul 08, 2022 5:50 pm
From the Wiki:
get <id> <param>=<value>
Would translate to:
get number=0 value-name=dns-server
rextended
Fri Jul 08, 2022 7:06 pm
From the Wiki:
Would translate to:
And?
First rule: do not use "print" numbers on script, this is wrong: number=0
    :local testip 3.4.5.6
    :if ( ([get [find where address="192.168.0.0/24"] dns-server] ~ [:tostr $testip]) or \
          ([get [find where address="192.168.1.0/24"] dns-server] ~ [:tostr $testip]) ) do={
      :put "$testip is present at least on one network as DNS"
    } else={
      :put "$testip is not present on the networks"
Wublide
Sat Jul 09, 2022 2:57 pm
thank you for joining the topic guys!
that's brilliant, thank you so much
one last question: I would like to not use the else in the if statement but to do that I suppose it's more clean to check if $testip is NOT present (so the IF statement is true if it's not present). How can I achieve that? using
    :if ( !([get [find where address="192.168.0.0/24"] dns-server] ~ [:tostr $testip]) or \
          !([get [find where address="192.168.1.0/24"] dns-server] ~ [:tostr $testip]) ) do={
rextended
Sat Jul 09, 2022 4:32 pm
for invert the results, you can not only "invert" the ckecks results, but also change the operator from "or" to "and"
when the "else" is executed?
When both are false: when A NOT containing the ip AND A NOT containig the ip....
A or B
true @ true = true ( executed if )
true @ false = false @ true = true ( executed if )
false @ false = false ( executed else )
A and B
true @ false = false @ true = false ( executed else )
!A or !B
true @ true = false ( executed else )
false @ false = true ( executed if )
!A and !B
true @ true = false ( executed if )
true @ false = false @ true = true ( executed else )
false @ false = true ( executed else )
Wublide
Tue Jul 12, 2022 7:06 pm
A or B
A and B
!A or !B
!A and !B
perfect, thank you so much
Users browsing this forum: No registered users and 19 guests
