ArShuRaZ
[ROS 7 Bug?] MikroTik cannot ping to any devices until reboot.
Sun Jul 10, 2022 7:54 am
I've face this issue on MikroTik CHR and CCR1072 with ROS 7.1.3, ROS 7.2, ROS 7.3.1.
When MikroTik has been using for a while (sometimes days, sometimes months) it will cannot ping to any devices (still can traceroute) so netwatch will malfunction but other modules are working fine.
Any solution to fix this? on CCR1072, I use schedule restart everyday and the problem do not happen again.
but on CHR, I use it as a production for 24x7 systems. Cannot just schedule restart. Everytime I want to reboot, I have to write a formal letter to notice several departments.
chechito
Re: [ROS 7 Bug?] MikroTik cannot ping to any devices until reboot.
Sun Jul 10, 2022 8:20 am
if you have connection tracking active check in ip->firewall->connections all the details of the ping connection which is not responding
ArShuRaZ
Sun Jul 10, 2022 8:48 am
Orig. and Repl. Bytes are increasing along the time I've ping. But status of ping is still timeout.
try remove those connections already. result still the same.
pe1chl
Sun Jul 10, 2022 12:16 pm
Maybe you can try upgrade to the latest stable version, or maybe better (when your usage allows it) downgrade to 6.49.6 ?
ArShuRaZ
Sun Jul 10, 2022 12:26 pm
I think so. downgrade would help.
but can I use wireguard with ROS 6 ?
If ROS 6 had wireguard, I definitely wouldn't use ROS 7 on my CHR.
(now 7.3.1 is the lastest stable version)
eworm
Sun Jul 10, 2022 11:19 pm
I guess this is the same issue:
viewtopic.php?t=185381
I am suffering the same, it is tracked in SUP-83146, Mikrotik reproduced it but a fix is pending.
eworm
Wed Aug 10, 2022 3:26 pm
This should be fixed with 7.5beta8, which includes this change:
*) ping - improved service stability;
Users browsing this forum: BoraHorza, elaszlo, Majestic-12 [Bot] and 170 guests
