Dragony
DynaDish 5 PtP connection not working...
Mon Jul 11, 2022 5:48 pm
Hi.
Ok I probably have made some stupid mistake somewhere, but I can't find it....
I have purchased 2 DynaDish 5 dishes. Both were factory set as station.
One is attached to an isolated computer. I accessed the Web Front-End there and left the settings as they were (at station). I just entered PSK2 details.
The other one is attached to the main network. I accessed the Web Front-End (of the second dish) there and changed "station" to "bridge". I saved the PSK2 credentials.
After that the connection was established. Both dishes show strong signal and Wireless -> Registration shows the connected Client. If I click on it, it also reports the correct IP of the remote dish under "Last IP".
So all should work, shouldn't it?
I can't ping the second dish. Not from my computer, neither via Tools -> Ping. BUT when I do a Tools -> Ping -> MAC Ping, I get a reply.
What could I have missed?
The whole network is in 10.0.0.0/8 and every device has a unique IP, so it can't be a routing issue?
nickshore
Long time Member
Long time Member
Re: DynaDish 5 PtP connection not working...
Mon Jul 11, 2022 5:51 pm
You probably need station-bridge on one end and bridge on the other
Dragony
Mon Jul 11, 2022 5:55 pm
Wow that was fast and yes, that was my mistake. Thank you very much. I wonder why that "station" more exists. Seems useless to me but a good trap if you just want to configure it as a station....
Users browsing this forum: No registered users and 14 guests
