ferdy1807
REST API Translate
Tue Jul 12, 2022 12:01 pm
I need help :( for some command in JSON where CLI like this - POST
/ppp secret set name=yyy numbers=[find name=xxx]
or another way for solving update data like that
Your help is very much appreciated..
mrz
Re: REST API Translate
Tue Jul 12, 2022 12:16 pm
You can run query with post
https://help.mikrotik.com/docs/display/ ... TAPI-Query
and then set
ferdy1807
Tue Jul 12, 2022 12:21 pm
https://IP/ppp/secret/set?numbers=[find name=xxx]
{"name" : "yyyy"}
I tried it at postman, it isnt works.
advice me how to translate here
mrz
Tue Jul 12, 2022 12:23 pm
You cannot run find via API. Look at the link provided above which shows how to run queries
ferdy1807
Tue Jul 12, 2022 12:28 pm
even though i put it inside query?
like this - POST body
{".query": [
"numbers=[find name=xxx]"
rextended
Re: REST API Translate  [SOLVED]
Tue Jul 12, 2022 12:33 pm
correct script way
/ppp secret set [find where name=xxx] name=yyy
extended syntax
/ppp secret set numbers=[find where name=xxx] name=yyy
First, GET the .id:
/rest/ppp/secret/name?name=xxx&.proplist=.id
(for example *5 )
Then PATCH that .id setting the new name:
/rest/ppp/secret/*5
{"name": "yyy"}
ferdy1807
Tue Jul 12, 2022 2:57 pm
Ok sir got it,
So we must do it at 2 step
Hope next we get more detail about REST :)
Thanks for advice sir
cherlow
Tue Dec 13, 2022 2:09 pm
I've tried patching on the ID to change the name but what ends up happening is that it creates a duplicate ppp secret entry with the name provided
Users browsing this forum: No registered users and 15 guests
