mihailJl
LHG 60Ghz after reset - wrong username or password..
Tue Jul 12, 2022 9:22 pm
Yesterday before I started configuration I did a full wipe. After that, I couldn't login anymore...
With Netinstal I tryed with both older and newer versions and still the same.
Login attempts were via winbox and web with the following data:
User - admin, pass -
User - admin, pass - b629-f1b4 (from the sticker)
Any suggestions on what to do with this "colander"?
rextended
Re: LHG 60Ghz after reset - wrong username or password..
Tue Jul 12, 2022 9:31 pm
Spaghetti?
I can not see any details on netinstall and routeros used, and on netinstall settings when started install.
Because you, at least, start install, right?
mihailJl
Wed Jul 13, 2022 11:00 am
At the firs the bord was with 6.45.
With netinstall I back up to 6.43..
On the next turn i trayed with 6.48
mihailJl
Tue Jul 19, 2022 9:34 pm
Its Done!
I try with version 7 and login with admin without pass. Then remove admin and created again with no password. Return to version 6.46, and loging without problems!!!
I don't know what happened...!
Users browsing this forum: cyrq, lurker888 and 36 guests
