2152
CCR2004-16G-2S+/Ethernet Port Problem
Wed Jul 13, 2022 8:18 am
Hi I am new to this forum, I am using a CCR2004-16G-2S+ from past 4 months everything was good, but today I seen ethernet port 2 enabled and disabled with in few seconds, IMPORTANT THING IT IS NOT IN USE. Can anyone help me out why this happened? I am attaching screenshots here and sorry for my English.
chechito
Re: CCR2004-16G-2S+/Ethernet Port Problem
Wed Jul 13, 2022 2:53 pm
which version of RouterOS you have installed?
have you updated RouterBoot on system->routerboard ?
rextended
Wed Jul 13, 2022 3:00 pm
I have seen the same problem on a device too close to the "air conditioner"...
Inside, moisture settles on the ethernet port and causes problems...
I solved it by directing the airflow elsewhere.
2152
Wed Jul 13, 2022 5:44 pm
Thank you for the reply, here is my rb version
Users browsing this forum: sch and 66 guests
