normis
Newsletter 106
Wed Jul 13, 2022 9:46 am
Read our latest newsletter and learn more about:
  • the new PoE versions of RB5009 and CSS610;
  • a new enterprise-level 100-gigabit switch with 1.2 Tbps switching capacity;
  • new accessories for the 100-gigabit product line;
  • US carrier-cerfified SXT LTE6 and Chateau LTE6;
  • latest MikroTips and tricks, and more!
https://mt.lv/News106
Video: https://youtu.be/x_QW_KZu7_M
wispmikrotik
Re: Newsletter 106
Wed Jul 13, 2022 10:52 am
rb5009 PoE 😍😍😍
eworm
Re: Newsletter 106
Wed Jul 13, 2022 11:05 am
I am surprised that we see a mention of RouterOS 7.3... Still a long way to go for version 7.4?
haedertowfeq
Re: Newsletter 106
Wed Jul 13, 2022 11:17 am
And NO wifi6 divce or wifiwave2 package for OLDER divces
THANK YOU GOODPAY FOR WIFI
MIKROTIK
troffasky
Re: Newsletter 106
Wed Jul 13, 2022 12:31 pm
What are those "loops" on either end of the RB5009?
kraal
Re: Newsletter 106
Wed Jul 13, 2022 3:22 pm
Why do you still use the old logo on newly released devices 3 months after having changed your branding ?
When do you plan to use the new logo ?
From a more technical viewpoint, why still only having a single 2.5Gbps port ?
normis
Re: Newsletter 106
Wed Jul 13, 2022 3:33 pm
New devices are usually designed many years before publishing
normis
Re: Newsletter 106
Wed Jul 13, 2022 3:57 pm
We also have a video accompanying the newsletter https://youtu.be/x_QW_KZu7_M
mkx
Re: Newsletter 106
Wed Jul 13, 2022 4:07 pm
These are needed to mount 4 devices (in 2x2 placement) in a 1U configuration.
mohamads
Re: Newsletter 106
Wed Jul 13, 2022 5:04 pm
I Just wished that RB5009 would have supported vlan filtering as hardware based. Could be a great replacement for Ubiquiti edgeswitch or at least make the same design of RB5009 for a switch so we are able to rackmount in a single 1U space 4 of them with stackable feature if possible to not loose some ports. It's good because if one goes down from a lightening or any other case we don't loose the whole switch. Cost wise really interesting for service providers.
I also have a question for Normis: Do CRS305-1G-4S+IN have vlan filtering capabilities ? if not, I guess mikrotik wiki should edit the section where it mentions all 3xx series have vlan filtering capabilities.
rextended
Re: Newsletter 106
Wed Jul 13, 2022 5:53 pm
15 years ago... this "newsletter":
http://www.roc-noc.com/pdf/RB133/rb133_brochure.pdf
chechito
Re: Newsletter 106
Wed Jul 13, 2022 5:58 pm
both devices you mention have hardware vlan filtering accelerated by hardware
RB5009
CRS305-1G-4S+IN
in fact CRS 305 can do Layer 3 forwarding by hardware (No fast-track No-NAT), rb5009 do Layer 3 forwarding by CPU but has a very powerful one
Bridge Hardware Offloading
https://help.mikrotik.com/docs/display/ ... Offloading
Switch chip features
https://help.mikrotik.com/docs/display/ ... p+features
L3 hardware offloading
tangent
Re: Newsletter 106
Wed Jul 13, 2022 6:13 pm
To be clear, the RB5009 is referenced by its CPU on two of those pages, 88E6393X. That's likely why the OP above missed it.
chechito
Re: Newsletter 106
Wed Jul 13, 2022 6:17 pm
with the intention of being clear:
RB5009 CPU is 88F7040, switch chip responsible of Layer 2 HW accelerated features is 88E6393X
ksteink
Re: Newsletter 106
Thu Jul 14, 2022 3:17 am
Nice releases!!!. I like to see the CRS5xx to replace the CRS326 and/or CRS328-24P with the following characteristics:
- 24 RJ45 Ports
- All or some Ports with mGig Support (2.5 Gbps and 5 Gbps!). If some at least 8 ports
- PoE+ or even better PoE++
- 4 x SFP+ cages
- 2 x QSFP cages
Any expected time frames to get these?
Wolfraider
Re: Newsletter 106
Thu Jul 14, 2022 10:41 pm
If we could get a router with 4 or 8 100Gb ports, I would purchase 3 right now
benlg
Re: Newsletter 106
Fri Jul 15, 2022 3:15 pm
@normis, do you confirm that the power-supply which comes in the RB5009UPr+S+IN box is the 48V2A96W (and not the 24V one which comes with RB4011 and previous RB5009) ?
Btw, really nice newsletter, awesome products :)
Many thanks !
rextended
Re: Newsletter 106
Fri Jul 15, 2022 5:12 pm
benlg
Re: Newsletter 106
Fri Jul 15, 2022 5:15 pm
@rextended, thank you, I saw, just asked for confirmation, as video for this new product shows a 24V DC-jack voltage...
Larsa
Re: Newsletter 106
Fri Jul 15, 2022 11:49 pm
qatar2022
Re: Newsletter 106
Sat Jul 16, 2022 10:47 am
i couldn't find RB5009UPR even in your distributors and must of your distributors website not exist
any recommendation seller accept paypal?
with regards
pcunite
Re: Newsletter 106
Wed Jul 20, 2022 6:19 pm
CSS610-8P-2S+IN looks good. Would prefer CRS (RouterOS).
benlg
Re: Newsletter 106
Wed Jul 20, 2022 8:16 pm
Would also prefer RouterOS on both CSS610 non-PoE and PoE versions.
Perhaps one day @MikroTik dev team ?
CSS610-8P-2S+IN properly replaces old CRS112-8P-4S-IN though :)
w0lt
Long time Member
Long time Member
Re: Newsletter 106
Wed Jul 20, 2022 9:26 pm
The RB5009 is presented as a great lab tool but for me, it falls short not having a serial port for external configuration. Might as well get a RB4011 without the wireless., thoughts?
benlg
Re: Newsletter 106
Wed Jul 20, 2022 9:28 pm
Simply dedicate one of the 8 RB5009 ports (which you can then (un)tag in your management VLAN) for local administration purpose ?
mkx
Re: Newsletter 106
Wed Jul 20, 2022 11:24 pm
Another possibility is to use woobm, it supposedly works on all ROS devices equipped with USB port.
chechito
Re: Newsletter 106
Thu Jul 21, 2022 12:28 am
another useful console use is managing another equipment by console through the MikroTik device with a null cable
r00t
Long time Member
Long time Member
Re: Newsletter 106
Thu Jul 21, 2022 1:22 am
+1 for proper serial console port, not just for management but also control of other devices. It's sad all devices from Mikrotik come with UART pads on PCB... but we can't use them in ROS, they are not software enabled - yet fully functional if you boot OpenWRT. If having <$1 in BOM cost of RS232 port is too much, at least have that 3.3V UART available on like a pin header.
chechito
Re: Newsletter 106
Thu Jul 21, 2022 1:42 am
ohh yeah specially with 229 USD tag price
mada3k
Long time Member
Long time Member
Re: Newsletter 106
Sun Jul 24, 2022 11:26 am
Agree. We simply have no use for CSS series because the lack of security.
Users browsing this forum: Florian, grusu, LabarH and 9 guests
