dalami
Current UPS support
Fri Jul 15, 2022 11:38 pm
The documentation for the UPS package is a little sparse but only mentions the APC product line as being supported. I've read elsewhere about other brands being used successfully.
Is this package based on the "Network UPS Tools" project and should therefore support any UPS of the adopted version? Are there specific drivers that are supported (hopefully including "usbhid-ups")? Or is the only brand explicitly supported APC?
dalami
Re: Current UPS support
Fri Jul 22, 2022 12:42 am
Can anyone comment on using a USB connected UPS with current routers? Preferably non-APC offerings - particularly Eaton or CyberPower?
Zacharias
Fri Jul 22, 2022 12:46 am
If you search in the forum you will find posts like this viewtopic.php?t=48762#p284203
mentioning models that are working...
dalami
Fri Jul 22, 2022 2:19 am
I saw that - but there's been limited comments for recent versions and many of them negative. I was hoping for something better.
Users browsing this forum: No registered users and 68 guests
