frankedwards
7.4rc2 container does not start after reboot
Sat Jul 16, 2022 11:16 am
It appears after upgrading to 7.4rc2 that containers do not start following a reboot.
Issue Report
1. Version number: 7.4rc2
2. Router Model: hAP ac³
3. Steps to reproduce the issue:
* Add the configuration and example container image as per the Container documentation (https://help.mikrotik.com/docs/display/ROS/Container)
[admin@MikroTik] > /container print
 0 name="32e88d3b-d744-4e02-96bd-b77d8d46a93d" tag="pihole/pihole:latest" os="linux" arch="arm"
   interface=veth1 envlist="pihole_envs" root-dir=disk1/pihole mounts=etc_pihole,dnsmasq_pihole
   dns="" status=stopped
* Container can be started:
[admin@MikroTik] > /container start 0
   dns="" status=running
* Stop the container and reboot
[admin@MikroTik] > /container stop 0
[admin@MikroTik] > /system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
* Attempt to start the container following reboot:
   interface=veth1 envlist="pihole_envs" mounts=etc_pihole,dnsmasq_pihole dns="" status=stopped
4. Configuration export
[admin@MikroTik] > /export hide-sensitive
# jul/16/2022 18:07:49 by RouterOS 7.4rc2
# software id = JI5E-5JQW
# model = RBD53iG-5HacD2HnD
# serial number = E7290E36E46D
add admin-mac=2C:C8:1B:FA:ED:3F auto-mac=no comment=defconf name=bridge
add name=cam
add name=dockers
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=\
    indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-FAED43 wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=\
    indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-FAED44 wireless-protocol=\
    802.11
/interface veth
add address=172.17.0.2/16 gateway=172.17.0.1 name=veth1
/container mounts
add dst=/etc/pihole name=etc_pihole src=/disk1/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/disk1/etc-dnsmasq.d
/disk
set usb1 disabled=no
set usb1-part1 disabled=no name=disk1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add address-pool=default-dhcp interface=bridge name=defconf
/system logging action
add name=dlog target=memory
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes \
    name=zt1 port=9993
/container
add envlist=pihole_envs interface=veth1 mounts=etc_pihole,dnsmasq_pihole
/container config
set registry-url=https://registry-1.docker.io
/container envs
add key=TZ name=pihole_envs value=Europe/Riga
add key=WEBPASSWORD name=pihole_envs value=mysecurepassword
add key=DNSMASQ_USER name=pihole_envs value=root
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
add bridge=dockers interface=veth1
add bridge=bridge interface=ether2
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=172.17.0.1/16 interface=dockers network=172.17.0.0
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=\
    !dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=\
    ether1 out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=ether1 src-address=172.17.0.0/16
/system clock
set time-zone-name=Australia/Brisbane
/system leds
set 0 interface=wlan1 leds=led1,led2,led3,led4,led5 type=wireless-signal-strength
set 1 leds=poe-led type=poe-out
/system logging
add topics=container
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
5. Any additional information that would help
No logging is shown when attempting to restart the container.
Logs on reboot:
 18:03:39 container,info,debug could not use root-dir: disk1/pihole, ignoring
 18:03:39 container,info,debug could not use tmpdir: disk1/pull, ignoring
 18:03:48 bridge,info "dockers" mac address changed to 42:BC:40:CF:81:10
rplant
Re: 7.4rc2 container does not start after reboot
Sun Jul 17, 2022 8:30 am
Perhaps those boot up log messages are meaningful.
Maybe disk1 becomes available after the container initialization.
(Which fails because disk1 is not yet available)
Can you perhaps put the container, and mounts into flash rather than disk1 and see if it works through a reboot then.
frankedwards
Sun Jul 17, 2022 11:15 am
Hi
Thanks. Looks like a lack of space prevents the container being installed to flash:
18:05:30 container,info,debug importing remote image: pihole/pihole, tag: latest
18:05:35 container,info,debug getting layer sha256:eeb117569618df53320eb28d32b7a1d87792bda3362017123fa1025b55db44c3
18:05:45 container,info,debug layer sha256:eeb117569618df53320eb28d32b7a1d87792bda3362017123fa1025b55db44c3 downloaded
18:05:51 container,info,debug no space to extract layer
18:05:51 container,info,debug was unable to import, container f9bec265-91c1-4506-854a-93680c2dc8f0
Container status:
 0 name="f9bec265-91c1-4506-854a-93680c2dc8f0" tag="pihole/pihole:latest" os="linux" arch="arm"
   interface=veth1 envlist="pihole_envs" root-dir=pihole mounts=etc_pihole,dnsmasq_pihole dns=""
   status=error
Regards
Frank
cklee234
Mon Jul 18, 2022 4:12 am
I use netwatch to monitor the container up and running after I confirm the container configuration works and it runs well
rplant
Tue Jul 19, 2022 12:12 pm
Hapac3,
I made a small container that does fit into the flash, and it is restartable on reboot.
it isn't running after reboot, but just needs a /container start 0 command.
(Note: I had to create the docker directory before it would create the iperf container in it)
Mikrotik maybe needs to delay container initialization till a bit later.
Also at present you cannot recreate the config from the export as it loses the file=iperf.tar section.
In this instance I also put this into the comment, as a reminder.
/container
add cmd="iperf3 -s" dns="" envlist=iperf file=iperf.tar \
hostname=iperf interface=veth1 logging=yes mounts="" root-dir=docker/iperf \
comment="file=iperf.tar"
frankedwards
Re: 7.4rc2 container does not start after reboot  [SOLVED]
Thu Jul 28, 2022 5:56 am
Hi
Thanks for your assistance. It looks like the issue is resolved for me in 7.5beta4.
Regards
Frank
Users browsing this forum: manigk, patg and 49 guests
