NilsRiver
Mikrotik groove wireless bridge can't access IP cam
Tue Jul 19, 2022 10:52 am
Hello everyone,
I'm using IP cams for work projects, usually connected to a PoE switch for data and current, the switch being connected to a computer or an nvr or whatever. The thing is that I need to equip a location where I won't be able to pull a long enough PoE cable. I have two MikroTik GrooveA 52 ac and my goal is to connect one of them to the IP cam, the other one to the computer or nvr and access the IP cam data from the computer/nvr.
From my research, I understand that creating a bridge between the two mikrotik devices could be a solution. Currently, I have been able to connect the two mikrotik devices together, one in bridge mode, the other in station bridge mode, using the nv2 protocol. I created a bridge on the eth1 and wan1 interfaces on both devices and assigned fixed IP adresses on the bridges, on the same subnet (192.168.88.X).
To test the network, my station-bridge mikrotik is connected by Lan to a computer. I can't access the IP cam adress and I really don't understand what more should I do. I tried using different subnets (my IP cam IP is 192.168.254.X) but it doesn't seem to work either. I tried to give my computer network board a fixes IP adress on the same subnet than the bridge to ensure that it can communicate with it, doesn't work either (+ I'm not sure if I should give it an adress on the same subnet than the bridge or than the eth1 port but whatever).
Following are my mikrotik configurations.
Bridge device :
[admin@MikroTik] > /export hide-sensitive
# jan/02/1970 01:32:27 by RouterOS 6.47.10
# software id = 3T9K-QFMV
# model = RBGrooveGA-52HPacn
# serial number = <CENSORED>
add name="Camera Bridge"
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    country=france disabled=no frequency=auto installation=outdoor mode=bridge \
    nv2-security=enabled ssid="MikroTik Veodis" wireless-protocol=nv2
add comment=defconf name=WAN
add comment=defconf name=LAN
# DHCP server can not run on slave interface!
add address-pool=default-dhcp disabled=no interface=ether1 name=defconf
add bridge="Camera Bridge" interface=ether1 trusted=yes
add bridge="Camera Bridge" interface=wlan1 trusted=yes
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=wlan1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
    192.168.88.0
add address=192.168.88.2 interface="Camera Bridge" network=192.168.88.2
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf disabled=no interface=wlan1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
Station-bridge device :
# jan/02/1970 01:20:55 by RouterOS 6.47.10
# software id = RWX4-XH9J
/interface wireless
    country=france disabled=no frequency=auto installation=outdoor mode=\
    station-bridge nv2-security=enabled ssid="MikroTik Veodis" \
/ip hotspot profile
add name=default-dhcp ranges=192.168.88.11-192.168.88.254
add address-pool=default-dhcp interface=ether1 name=defconf
    192.168.88.0
add address=192.168.88.3 interface="Camera Bridge" network=192.168.88.3
/ip dhcp-client
/ip dns static
    invalid
    invalid
/tool mac-server
Also, I'm new to networking so if you see that I'm confused on specific concepts please feel free to explain.
And yes I know i'm probably using outdated routeros version but will ofc update it before really installing the network.
Thank you very much for your help, i'm really getting crazy here.
NilsRiver
rextended
Re: Mikrotik groove wireless bridge can't access IP cam
Tue Jul 19, 2022 11:05 am
you try to delete all firewall rules?
better, if you want only use the devices as bridge,
do a full reset, without keeping anything and without default config
at that point,
use winbox by MAC, create a bridge, put both wlan1 and ether1 to a bridge,
set 1st device wlan1 as bridge, with nv2 password
do the same on the other side, but choice station-bridge,
and the basics things are done.
what coming after that, like IP or DHCP Client on bridge (not on ether or wlan) is another thing.
NilsRiver
Tue Jul 19, 2022 3:14 pm
Just a precision I forgot in the first post :
My IP cam isn't directly connected to my mikrotik bridge router, I use a switch because the IP cam is powered by PoE (I can't power it differently). I would say that it shouldn't be a problem, but i'm not that knowledgable so you know, if you think that's an obstable tell me.
at that point,
Thank you for your answer. That's actually exactly what I did but I can't remember if I ever did it all at once so i'm going to try and I'll give you the results.
NilsRiver
Tue Jul 19, 2022 3:50 pm
Ok so I did what rextended said so my two routers are wirelessly connected and the eth1 and wan1 port of both are brdiged. However, I still can't access my IP cam and I didn't setup any IP adresses, neither for the bridge nor the ports.
From my point of view, what's next is to configure an ip adress for the bridge on the same subnet than my routers ports so that they can communicate, is it ? This is the point I get confused and usually brindly follow tutorial recommendations, but it's not been very useful to this day.
NilsRiver
Re: Mikrotik groove wireless bridge can't access IP cam  [SOLVED]
Tue Jul 19, 2022 5:34 pm
OK it's working.
I simply setup manually an ip adress for each of my interfaces (bridge, wan1 and eth1) on the same subnet, using the default one of mikrotik (192.168.88.X). I did it for each device, the station bridge one and the bridge one.
Then, i changed the ip adress of my camera to match the mikrotik subnet.
Previously, I did a setup with the same logic but instead of changing the camera ip I changed the mikrotik routers IP and it didn't work. I'm not sure why, maybe I didn't do it properly out of lack of focus.
Anyway, it works like a charm now, even on a NVR so i'll be able to use it for my project.
I hope that someone with the same difficulty will find this topic.
Thank you very much
NilsRiver
Users browsing this forum: No registered users and 46 guests
