emils
Forum Veteran
Forum Veteran
WinBox v3.37 released!
Tue Jul 19, 2022 12:39 pm
What's new in v3.37:
*) do not update interface window layout all the time;
*) do not send value for empty multi-option field;
*) fixed VPLS "cisco-id" field with "&" prefix (introduced v3.36);
*) fixed ability to set options that can be hidden;
*) fixed floating point field's negative value in -0.*** format;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
nichky
Re: WinBox v3.37 released!
Tue Jul 19, 2022 1:57 pm
*) do not update interface window layout all the time; - what u mean by that?
Unintentional
Tue Jul 19, 2022 1:58 pm
Confirmed fixed rate selection issues on my end.
rextended
Tue Jul 19, 2022 2:06 pm
Winbox 3.36 on 6.48.6 can not save wireless settings, like data rates, tx-power, tx-power mode, etc. on mibsbe (i do not check others)
On CLI work correctly as expected, and the changes are reflected on winbox
Now work as expected, thanks.
mrigi
Tue Jul 19, 2022 2:31 pm
Would love to see less resources used when open "interface list" on something big and slow like crs354. It takes up to 40% of switch cpu just to refresh that list. Not doing any real job. A bit annoying.
mkx
Tue Jul 19, 2022 5:02 pm
This makes clear that CRS354 should have had ARM cpu, not MIPSBE one ...
guipoletto
Tue Jul 19, 2022 7:55 pm
Agreed.
CRS317 and CRS326-24G-2S+ were in the right path.... and then they decided in CRS5XX to... reuse the pithy qca9531? WTH
That kinda scares-me, as the slightest mishap/misconfig that lets the tinyest ammount of traffic leak into the management vlan will crap out the CPU
raffav
Tue Jul 19, 2022 11:20 pm
is only me but since the 3.36 and 3.37 I can't download via the application when I ask to update winbox does not do nothing just aa empty space where suppose to be "change logs"
rextended
Tue Jul 19, 2022 11:27 pm
for me work already on both 32 and 64 bit
try to delete winbox working folder
mrigi
Tue Jul 19, 2022 11:29 pm
However the cpu load been lower on v6. So I bet there is a room for the software improvement too.
raffav
Tue Jul 19, 2022 11:30 pm
I moved to another place the exe but keep no changes, I will try in another windows 11, can be my AV or something else
Znevna
Tue Jul 19, 2022 11:33 pm
I couldn't update via the app either, had to manually download it.
rextended
Tue Jul 19, 2022 11:38 pm
Just rechecked, some seconds ago work, now not work....
Probably some cloud problem???
Znevna
Tue Jul 19, 2022 11:39 pm
I don't know, I lost interest in doing debugging for free.
holvoetn
Tue Jul 19, 2022 11:50 pm
Confirmed.
I could upgrade somewhere in the afternoon, doesn't work anymore now.
rextended
Tue Jul 19, 2022 11:55 pm
For be specific, do not work also on some old winbox versions, is not the latest 3.37 the problem.
raffav
Tue Jul 19, 2022 11:56 pm
does someone knows where I can find the old version like 3.34< in mikrotik sites?
rextended
Wed Jul 20, 2022 12:03 am
can, for curiosity, ask why?
raffav
Wed Jul 20, 2022 12:06 am
try to see if i can upgrade via app i have 3.5 3,6 and 3.28 but a this stage there was only 32bit so
edit:
i guess the issue is on the server side they might have chance something
rextended
Wed Jul 20, 2022 12:08 am
Use this as model:
https : // download.mikrotik.com/winbox/<VERSION>/winbox<ARCH>.exe
where <VERSION> is 3.xx and <ARCH> can be for 32 bit nothing and for 64 ... 64 !
raffav
Wed Jul 20, 2022 12:13 am
thanks but still don't work so i will guess it is a server side problem
anav
Wed Jul 20, 2022 12:22 am
I would be happier if some efforts were also made to update IOS MT application.
holvoetn
It does work if you remove the spaces from the conceptual model rextended provided.
I was able to download 3.34 32-bit without problems.
holvoetn
Wed Jul 20, 2022 12:23 am
Majority of the world is on Android, my friend ...
raffav
Wed Jul 20, 2022 12:32 am
not talking about the link to download old version, that work
i'm talking about making the app auto upgrade to last version when you ask for< when I press check for update the "change log" blank and does not do nothing...
Znevna
Wed Jul 20, 2022 1:06 am
Ok, maybe one more time.
upgrade.mikrotik.com is an alias for download.mikrotik.com.
download.mikrotik.com has address 159.148.172.226
download.mikrotik.com has address 159.148.147.204
download.mikrotik.com has IPv6 address 2a02:610:7501:4000::226
download.mikrotik.com has IPv6 address 2a02:610:7501:1000::204
159.148.172.226 and 2a02:610:7501:4000::226 are broken.
159.148.147.204 and 2a02:610:7501:1000::204 work fine.
Either wait for MikroTik to fix the broken server or define those records locally without the currently broken one.
hah, the bad battery post.
deadkat
Wed Jul 20, 2022 5:34 am
this mentioned and resolved in several places on the forum. please use the search bar before asking questions.
one example (literally what Rextended said): viewtopic.php?p=813908
I keep a txt file on my laptop with the following so I can remember how to get older versions if I need to....sometimes I come across an ancient device that has not been updated for years and it needs an older version of winbox to connect to it.
change version number in url for what is needed
https://download.mikrotik.com/winbox/3.25/winbox.exe
really old versions will be here instead
http://download2.mikrotik.com/routeros/ ... winbox.exe
rzirzi
Wed Jul 20, 2022 9:30 am
I can confirm it too.
holvoetn
Wed Jul 20, 2022 9:42 am
For me it works again.
Must be some change needing time to ripple through.
Znevna
Wed Jul 20, 2022 3:51 pm
You just ended up on the working server, that's all.
.226 and ::226 are still not working.
HTTP replies are different too.
the broken .226 responds with:
HTTP/1.1 200 OK
Server: nginx/1.18.0
and the working .204 responds with:
HTTP/1.1 200 OK
Server: ThirdWorldFileDaemon
anav
Wed Jul 20, 2022 6:25 pm
Only if its a One Plus according to the minority users in our fam - everyone else is iphone!
We dont need bidets either!!
JJT211
Wed Jul 20, 2022 10:26 pm
Was able to update directly from Winbox at home, but cannot update at work???
Znevna
Wed Jul 20, 2022 10:35 pm
Read the previous posts, sheesh.
Znevna
Fri Jul 22, 2022 2:10 pm
3 days later, .226 server still can't serve WinBox updates, any fix for this, MikroTik?
rumahnetmks
Mon Jul 25, 2022 10:51 am
Got bugs only view .
How to produce :
* When access mikrotik, using Winbox head to IP>FIREWALL then tab RAW.
* As example I have 72 RAW rules (info bottom left interface 72 items). But the winbox gui when we scroll down only have max around 50% of it. As fo my case show around 35 36 items only.
* Try close the IP>FIREWALL window and try open it again.
* All 72 RAW rules will be shown.
Note : If we close the winbox, the bug will be happen again.
Not important but somehow annoying. The bug itself I think have occurred since Winbox 3.35
Hope dev can look for it. TYVM.
#Last update, after update to v7.7stable, this bug dont happen anymore.
kikikaka
Mon Jul 25, 2022 4:49 pm
How to produce :
Same bug with rb5009. The bug happened since prev version (3.36 ?) and still exists in 3.37.
Actually u dont need to close and open again, just resize the window, all the rules come back.
I guess it is winbox UI bug.
Guscht
Mon Jul 25, 2022 10:14 pm
The bulit-in updater fails...
Znevna
Mon Jul 25, 2022 10:21 pm
Read my few replies from above, ffs.
IntLDaniel
Tue Jul 26, 2022 2:56 pm
Any chance to fix this viewtopic.php?p=938420#p938367 simple issue of not sorted Address List in DHCP static lease drop down option? Reported already many times, thanks
pe1chl
Fri Jul 29, 2022 4:56 pm
Please in a next release change the format of the files used by winbox (.cdb, .viw) from binary to some human-readable format like JSON or XML.
As a transition mechanism, Winbox would still be able to read binary files but would write them in the new format (new extension). When reading, it reads the new format when available.
Znevna
Sat Jul 30, 2022 10:09 am
10 days later, one server still doesn't provide upgrades, are we fixing it @MikroTik or taking it off the DNS list?
pe1chl
Sat Jul 30, 2022 11:41 am
Is MFA on the roadmap for WinBox?
Our cybersecurity is requiring MFA on all the network stack for management.
Put your management in a separate VLAN or at least a separate IP range and you can use a VPN as a second factor.
Whatever you do, NEVER open the Winbox port to access from the general internet! That is unsafe even when MFA would be in place. ALWAYS use some VPN or list of allowed source addresses!
holvoetn
Sat Jul 30, 2022 1:16 pm
Agree.
When you're arriving at Winbox, you already passed the front door.
Znevna
Tue Aug 02, 2022 5:06 pm
If you want something fixed, file a bug report, I always say. So I did.
As of now, the .226 server is back in business serving winbox upgrade requests.
bpwl
Tue Aug 02, 2022 9:42 pm
Winbox 64 bit, v3.37 (but already v3.35, v3.31) does not list the disks under System/Disks.
There are no disks in the dropdown list for 'Format Drive'
Happens on ROS 6.46.8 (hEX and hEX PoE) On some routers it works, on others it does not. (Same router type, same WinBox version and same ROS version)
Terminal "disk print" is always OK. Webfig is always OK.
Older Winbox v3.29 is sometimes also OK. (e.g. For ROS 4.47.10), but that is yet another hEX PoE.
Pffff hard to test, as some work others not, is it version or device specific?
Current workaround: don't trust System/Disks in WinBox, even for v3.37
holvoetn
Tue Aug 02, 2022 9:46 pm
It works on my Hex, FWIW.
Already tried to clean the Winbox folder on your machine ? Best to copy it aside, in case you still need info from there.
bpwl
Tue Aug 02, 2022 10:01 pm
Removed 6.46.8 directory in ...\AppData\Roaming\Mikrotik\Winbox
New descriptors downloaded .... no change (this is normally common for all my hEX on 6.46.8 , some work some don't)
Removed that 'IPaddress'.viw from ..\AppData\Roaming\Mikrotik\Winbox\sessions . No change in behavior
pe1chl
Wed Aug 03, 2022 12:10 pm
This situation is the reason for my request viewtopic.php?p=948630#p948630 above (#40).
When there is some subtle corruption in a winbox file, at least give us the possibility to look at it and maybe fix it without throwing away everything!
alexspils
Thu Aug 04, 2022 11:05 pm
FEATURE Request
add possibility to filter mac address in cisco like style aaaa.bbbb.cccc
for now its supports aa:bb:cc:dd:.ee:ff , aa-bb-cc-dd-ee-ff , aabbccddeeff formats
Jotne
Thu Aug 04, 2022 11:24 pm
Simple solution for this is just to strip off all that is not [0-9a-fA-F]
rextended
Fri Aug 05, 2022 12:27 pm
I want represent MAC with Rex's style:
(000000.0.0):0C:42-09:04:FE
Kraken2k
Fri Aug 05, 2022 3:42 pm
When I open the "IP - Firewall - Filter" window and try to move the "#" column (the one with order of the rules), Winbox throws the following error:
rextended
Fri Aug 05, 2022 4:12 pm
I confirm, but I'm curious why you want move that column, just for find a bug?
Guntis
Fri Aug 05, 2022 4:25 pm
The issue has been reported to developers, thank you for the report.
Kraken2k
Wed Aug 24, 2022 5:22 pm
It was an accident :) I wanted to move another column - so just a random find.
osc86
Thu Aug 25, 2022 10:33 pm
IP/Kid Control/Devices: why is the traffic shown in bytes? Please make it show in gigabytes or at least megabytes.
Jotne
Thu Aug 25, 2022 11:05 pm
Why. It would be hard to handle in external programs if this changes. In Splunk dashboard "MikroTik Device Traffic" that uses Kid Control, I can set the scale that would be useful to see on the graph.
pe1chl
Thu Aug 25, 2022 11:27 pm
In general it could be a useful feature in winbox to have some selectable output format for fields.
E.g. I would like a date field to be shown in YYYY-MM-DD format, no month names or "optimization" for "today".
Similar to the above request to show bytecounts in larger units.
Jotne
Thu Aug 25, 2022 11:42 pm
For the view part in WinBox, It could be Ok that select scale, as long as original data are used behind.
Time format are a big mess in RouterOS/Winbox. It should use a standard format and not different type depending on where you look and if its some hour back or days back,
osc86
Thu Aug 25, 2022 11:47 pm
Kid control is a feature clearly intended for home usage.. whatever your need is to export this data to something like splunk.
The raw data could still be counted / exported in bytes, this topic is about winbox, it'd be easy to convert it to reasonable values and just display it in megabytes/gigabytes in WINBOX.
Vlad2
Wed Aug 31, 2022 9:57 am
Identified such a problem:
1. Go to the list of users, select any user.
2. Click on the user and in the window that appears on the right, select the "Password" command and change the password, this is where the bug will be:
a) if you change the password and click "OK" - everything will be fine,
but
b) if you change the password (enter a new password and confirmation and click "Apply" there") and then just click the "OK" button - there will be an error.
And although nothing changes, such a glitch is very unpleasant. This did not happen before, you often change the password via Apply, and then OK.
Winbox 3.37, ROS 6.49.6 (checked, the problem is on two different computers and on two different routers).
(sorry for terribal English)
rextended
Wed Aug 31, 2022 12:28 pm
Beyond the bug, which do not happen on 6.48.6, it has always bothered me to see colleagues who first click on Apply and then immediately on OK...
I have always found it useless and a waste of time.
The "bug" occurs on 6.49.x
For the developers:
The bug occurs because the "Apply" button exists.
When clicking on "Apply" the password is changed.
By subsequently clicking on OK, in previous versions the password was changed once again.
On RouterOS 6.49.x has been set the check that the password is not the same as the previous one.
So when you click on "OK", the system tries again to change the password, ignoring if it has already done "Apply"
and then rightly gives error because it is the same as the password just set by "Apply".
Solution: Remove the "Apply" button.
bpwl
Wed Aug 31, 2022 4:55 pm
Why not just make it "operator proof"? Either using "apply", "apply+OK", "just OK" should work as expected.
Not all worlds of experience are equal. I have many other systems where just OK would not change anything.
https://answers.microsoft.com/en-us/win ... d25e761c0d
"No, they are different.
"Apply" puts into effect the change you made.
"OK" puts into effect the change you made and closes the dialog.
But note that that last sentence, about "OK," is the way it's
supposed to work; it's generally true, but it's not 100%. There's an
occasional exception to that and in such a dialog, "OK" just closes
the dialog and doesn't apply the change. So if you're not sure, it's
safest to first click "Apply," and then "OK."
Ken Blake, Microsoft MVP"
rextended
Wed Aug 31, 2022 5:06 pm
Remove "Apply" remove any doubt...
The change are applied on "OK" and the window are closed instantly.
(one click, without useless click)
or
Remove "OK" remove any doubt...
The change are applied on "Apply" and the window is closed after pressing the "X" window button.
(same numbers of click)
pe1chl
Wed Aug 31, 2022 7:28 pm
In the "quick setting of password" (System->Password) window there are "Password" and "Cancel" buttons. Not very intuitive.
Indeed in the Password... window under User entries there is OK, Cancel and Apply.
- it should be made consistent between these windows
- an Apply button is only useful in windows that have a lot of info, that you sometimes may want to set in increments or want to do/undo.
- it is not relevant (for this case) what bugs may exist in Microsoft software.
holvoetn
Wed Aug 31, 2022 8:23 pm
Uh ?
Microsoft SW has bugs ??
Now that's new ...
bpwl
Fri Sep 09, 2022 4:04 pm
Is that enoying missing screen update back in Winbox Terminal? Has been solved in an earlier release. Seems to be back.
Scrolling in the Terminal Window corrupts the display (pixels are moved to the wrong place). Happens with WinBox 3.35 and 3.37, both 64 bit.
Happens with ROS 7.5 on hAP ac3 and ROS 6.49.6 on hAP ac2. So it is WinBox related ???
Pressing "shift" refreshes the screen, all bits OK again, untill you scroll.
Znevna
Tue Sep 13, 2022 1:12 pm
I don't know how old this is or if it's recently introduced, but it's annoying: if the last opened tab on any interface is one of "General, Ethernet, Loop Protect" and you open an interface and you switch to any of these tabs: Overall Stats, Rx Stats, Tx Stats, Status, Traffic you can't use ESC to close that window anymore.
If the last opened tab is one of those last ones mentioned (*Stats, Status, Traffic) and you switch to any other tab, ESC works fine.
The behaviour is the same on other interface types too, not just Ethernet.
Weird little bug.
LE: I've tested with 3.15, same thing. So it's an old one.
bpwl
Tue Sep 13, 2022 3:26 pm
"an old one"
The "déjà vu" .... viewtopic.php?t=161980&#p798326
rextended
Tue Sep 13, 2022 6:51 pm
I remember this bug from WinBox 2.x on RouterOS 4.x.... is a very old one...
chechito
Thu Sep 15, 2022 3:43 am
in terminal i always scroll by full pages clicking on empty space on lateral bar to avoid this, i dont know in which version this returned
rextended
Thu Sep 15, 2022 10:56 am
I do not notice when it is disappeared...
AidanAus
Thu Oct 13, 2022 1:24 am
I would like to request that the output of the saved manage routers file be encrypted so you cant just open the .cbd file in notepad and see all the saved credentials in plain text, even having a master password before outputting the file would be better than it is now.
I know that work stations are supposed to be locked down etc but I feel that this is a major security risk and do not suggest using the managed routers feature in winbox before this is fixed :)
Sob
Thu Oct 13, 2022 7:08 am
Maybe I'm misunderstanding something, but doesn't your WinBox have "Set Master Password" button? Mine does.
AidanAus
Fri Oct 14, 2022 6:58 am
yeah forgot about that option but its still not enough to protect yourself. just looked and you dont need to even save the file for an addresses.cdb file to be make, look at C:\Users\(username)\AppData\Roaming\Mikrotik\Winbox as it uses this for your manage logins anyways.
holvoetn
Fri Oct 14, 2022 8:00 am
Things like this should in my opinion be handled on OS level, not application.
Use Bitlocker and a separate USB key.
When your PC get stolen or compromised, nobody can access that data without the key.
Sob
Fri Oct 14, 2022 4:56 pm
@AidanAus: Yes, there's default %APPDATA%\Mikrotik\Winbox\Addresses.cdb and it's initially unencrypted and everything in it is readable (it's a bit of binary mess, so not exactly user friendly, but not secure either). Once you set master password, the file gets immediatelly encrypted. And based on quick test, even when you move it using File->Save As..., it will save the encrypted version (if you didn't set master password, then it saves readable version; in other words, it keeps source format). It seems to me that your wish was already granted, just set the password.
@holvoetn: It depends. If it's handled by OS, you have to trust the OS maybe a bit more than you want to. You may also want to just move the file elsewhere, either as backup, or send it to someone (with password sent using some other secure channel), etc. So independent protection is not bad either. Only if you have more things like this, it's annoying to have to enter too many passwords.
dnordenberg
Thu Nov 17, 2022 11:18 am
In NDP/neighbor list there are a lots of ways to interact with a entry, ping, telnet, mac telnet and so on but why isn't there a winbox option? (open a winbox session against selected entry).
It could try to connect using same login as current connection or if the address is found in winbox saved/managed list it can use that instead.
bpwl
Thu Nov 17, 2022 12:55 pm
Check Romon for Winbox access to neighbor
Maggiore81
Trainer
Trainer
Thu Dec 01, 2022 9:21 pm
We still have issues on 7.6 . When we open for example the queue list, we cannot see all the queues, we need to resize and then maximize.
fs0c13ty
Fri Dec 09, 2022 10:31 am
please apply same zoom level of first window (which ask for ip password of mikrotik device) to second window(router os configuration window).
Njumaen
Wed Dec 21, 2022 9:08 pm
Feature Request: commandline connection to RoMON to see its RoMON Neighbors
something like
winbox.exe --romon <ip> <user> "<passwd>"
should result in showing the RoMON neighbours of <ip> from where further connections could be made.
Very useful as tool in The Dude...
Or maybe something like "RoMON" underneath "new WinBox" to connect to RoMON of the current session if RoMON is enabled?
Thank you.
Kraken2k
Tue Dec 27, 2022 3:06 pm
I've been struggling with this too - in the end, I've used directory junction to redirect the %APPDATA%\Mikrotik to an encrypted VeraCrypt drive (which is represented by one big file, used also for storing the web browser cache and other potentially sensitive data). So far, seems like the best solution for me - for the machines, where the whole sysdrive is not encrypted by BitLocker or similar
pe1chl
Tue Dec 27, 2022 3:26 pm
This is normally not an issue because usually on Windows 10 systems the %APPDATA% directory is encrypted by Bitlocker even when the entire system drive is not.
bajodel
Long time Member
Long time Member
Wed Dec 28, 2022 3:46 pm
I've just noticed that winbox is showing me only the first 68 rows of /ip/firewall/mangle on opening.
As soon as I select some subchain (other than 'all') and get back to 'all', it shows me all the lines (106 rows).
Yes, I'm using session templates but even of I select a new one ('own' new one) it shows me only 68 rows.
Using 'none' as session, it shows 69 rows, I'm a little bit confused.
Also switching to other tab (filter, nat) and then getting back to mangle, it seems to fix the rows number issue.
Anyone noticed a similar behaviour or am I just getting mad ? :-)
pe1chl
Wed Dec 28, 2022 5:24 pm
What RouterOS version are you running?
Is that only for mangle rules? I do not have that many so I cannot quickly test, but I have 246 filter rules (the first tab) and they are all loaded.
(I usually select a chain filter to limit the amount of screen update processing)
bajodel
Long time Member
Long time Member
Thu Dec 29, 2022 12:59 pm
Winbox is the latest 3.37, RouterOS is 7.7rc3 .
I'm pretty sure the issue was also present on previous 7.7rcX, but I suspect it was not there on 7.6 but I could be wrong and I need to find a way to check.
I don't remember seeing that on the filter tab, in mangle it's consistent every time I open a new connection and I display the mangle tab (first time).
I've just did a new check and also the NAT tab suffers the same issue (truncated at line 34 of 50 rows), switching the focus to mangle and back to nat and all rows are displayed.
The filter tab seems to be unaffected.
It's just a cosmetic thing, but it's annoying.
rumahnetmks
Thu Dec 29, 2022 4:43 pm
I have post about it post number #35 viewtopic.php?t=187734#p947514 ... yeah it's annoying ^_^
pe1chl
Thu Dec 29, 2022 4:50 pm
Ok but is it a prerequisite to have RouterOS v7? I manage several routers with very complex firewall setups but they are all running v6.49 (due to broken BGP in v7) and there I see no such issue.
My test routers running v7 have shorter firewalls, but I could experiment with one (load up a long dummy list of rules).
bajodel
Long time Member
Long time Member
Fri Dec 30, 2022 8:32 am
Sure @pe1chl, I've plenty of RouterOS v.6 as well and this issue in not present.
In practice, I play around with RouterOS v.7 only in my Lab (just few rare exceptions where I can't help myself).
Thanks @rumahnetmks for confirming the issue (I see you wrote it was present since winbox 3.35).
rumahnetmks
Fri Jan 13, 2023 10:55 am
@bajodel, I have installed v7.7stable and this bug is not happen anymore. Can you confirm?
I try reboot my router and usually it can reproduce the bug, but it seems not happen anymore.
EDIT :
Somehow the bug happen again. CONFUSE :D
bajodel
Long time Member
Long time Member
Sat Jan 14, 2023 1:41 pm
@rumahnetmks - nope, still happening here :-(
pe1chl
Sat Jan 14, 2023 2:00 pm
There are some cases where inexplicable Winbox behavior is caused by a corrupt session file.
You can try to make a connection with a new session file and check if it still occurs.
(this is the .viw file in the roaming profile directory)
bajodel
Long time Member
Long time Member
Sat Jan 14, 2023 4:31 pm
There are some cases where..[cut]
you're right, in fact I've already tried also with a blank new profile w/o success.
pe1chl
Thu Jan 19, 2023 11:03 pm
Feature request: make filters work (as much as possible within the limitations of the API) on the router side, rather than on the winbox side.
E.g. when I show IP->Routes with filter "Active is yes", send the query with "?active=true" to the router, rather than fetching all routes and showing only those that are active.
accarda
Mon Jan 23, 2023 6:56 am
In my case the issue of not seeing all data from firewall tables (in my case it's not limited to specific tab), when using Ros v7.x (I'm now on v7.7), is that on sections where there are lot of rows, Winbox does not show the lateral scrolling bar once I open a tab.
But if I switch to another tab and then come back to the other I wanted to see, then scroll bar is there and I can see all lines.
I have it with firewall/raw, but also address-list an so on with firewall menu.
It does not happen to me with /ip/route, even though the list is long enough. It appears more on the /ip/firewall that is multi-tab window and can get long even when opened in full screen.
pe1chl
Mon Jan 23, 2023 12:05 pm
I don't think I can reproduce that. But maybe I don't have enough rows, the correct RouterOS version, and/or I misunderstand the problem.
In any case, when you have such a problem, always try to connect without a session file to see if it can be reproduced with no- or fresh session file.
accarda
Mon Jan 23, 2023 12:13 pm
Ok, I will try later this evening and let you know, as I can always reproduce this problem with firewall tabs.
accarda
Mon Jan 23, 2023 8:04 pm
I have just tried again, but I get the same issue.
So I have connected to the router by setting winbox's session to "none" (I guess it's what you have asked to try), but when I open /ip/firewall/raw I don't see scrolling bars, until when I switch to another tab and come back.
Same behaviour as when I use session.
However if I use session, and I exit winbox by pointing the same menu/tab where scrolling bar disappears, once I reconnect through winbox within the same session, this time when firewall/raw is opened I have scrolling bar and can see all rows.
So as long as I exit winbox leaving the affected menu/tab selected, next time I re-open it, scrolling bars are there, otherwise if I start from another menu sequence, once I re-connect and I go into that menu/tab, no more scrolling bar until when I cycle to another tab and come back to the same menu/tab.
spippan
Wed Jan 25, 2023 2:40 pm
[feature request]
WinBox Keyboard hotkey navigation
viewtopic.php?p=980023#p980023
fs0c13ty
Mon Jan 30, 2023 3:15 pm
feature request
add software-id column in winbox neighbors discovery section.
Babujnik
Wed Feb 01, 2023 8:12 am
Any news of native for Linux/MacOS version of winbox ?
DanielTheFox
Wed Feb 01, 2023 7:24 pm
It runs on Wine on my laptop with Debian just fine. Even the old Wine in Debian stable repos can run winbox just fine.
jbl42
Wed Feb 01, 2023 9:50 pm
software-id column is available in neighbor window in Show Columns... menu (down looking arrow on the right)
But a long standing feature request is that WinBox keeps selected columns and does not set them back to defaults for every new session.
pe1chl
Wed Feb 01, 2023 9:54 pm
What?? It does that perfectly fine for me. Make sure you specify a session file (e.g. <own>) in your connection.
jbl42
Wed Feb 01, 2023 10:33 pm
After wiping out sessions and creating a new one it indeed works.
I'm happy to stand corrected!
pe1chl
Wed Feb 01, 2023 11:17 pm
Winbox is known for its bad handling of incorrect session files (which it creates itself in older versions).
Some very nasty problems can only be solved by starting a new session...
My suggestion is to use a new human-readable format for session files (like XML or JSON), with backward compatibility so new winbox can read old style files but will write new style, and then we can correct errors with a text editor.
I made some effort to decode the session files but there is too little information in the current format to decode/display them in a standalone tool.
vuk
Thu Apr 20, 2023 12:21 pm
hi all!
any news about new winbox version? it's been quite some time since the last release, something big might be prepared for release behind the curtains? :)
rextended
Thu Apr 20, 2023 12:28 pm
rolling
Thu Apr 20, 2023 12:56 pm
@Mikrotik team, can you add on top right size of winbox the posbility of add other resources like temperature?
thanks.
EdPa
Tue May 02, 2023 11:56 am
WinBox v3.38 is released.
viewtopic.php?p=999506#p999506
Users browsing this forum: naxus and 26 guests
