JackNE
ROS7.4 tx-power problem
Thu Jul 21, 2022 11:18 am
I have problem, after upgrade ROS 6.4x to 7.4.
Tested on SXT Lite5 and LDF 5, in wireless - country=no_country_set; frequency mode=superchannel; in tx power - tx power mode=all rates fixed; set 5, 10 or 15 dbm, settings don't save and reset tx power mode to default.
On ROS 6.4x all is works.
How fix problems?
erlinden
Re: ROS7.4 tx-power problem
Thu Jul 21, 2022 11:26 am
Why don't you configure properly, like i.e. setting country code?
Ca6ko
Long time Member
Long time Member
Thu Jul 21, 2022 11:31 am
Use the CLI.
rextended
Thu Jul 21, 2022 11:59 am
Update Winbox to 3.37
JackNE
Thu Jul 21, 2022 3:27 pm
Ok
I will try again.
Users browsing this forum: jaclaz and 78 guests
