Tsatsralt
Need help with port forwarding
Fri Jul 22, 2022 6:05 am
Hello guys.
New here and looking for an help. We have an NVR inside an local network and Microtik router on WAN. I have been trying to watch live view and playback video from PC client and mobile app from Internet. I've configured NAT and were able to log in using mobile app and PC client.
The problem is I can't watch any live feed or playback.
Tried 2 different NATs. disabled unnecessary NATs for now.
From what I saw, main 2 port that needed to watch live feed is 443 and 9100.
NVR is Dahua's DHI-DSS7016DR-S2.
I've hidden public IP for security concern.
Also I can watch and control NVR from the local network without any problem, so there is no need for additional configuration in NVR.
So I must be doing something wrong with the Mikrotik.
add action=accept chain=srcnat dst-address-list=loc src-address-list=loc
add action=dst-nat chain=dstnat dst-address=[Public IP] dst-port=15455 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 to-ports=443
add action=dst-nat chain=dstnat dst-address=[Public IP] dst-port=9100 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 to-ports=9100
add action=dst-nat chain=dstnat dst-address=[Public IP] dst-port=8080 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 to-ports=80
add action=masquerade chain=srcnat out-interface=ether1 src-address=\
    192.168.0.30
add action=dst-nat chain=dstnat disabled=yes dst-address=[Public IP] \
    dst-port=9090 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9090
    dst-port=9320-9322 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.0.30 to-ports=9320-9322
    dst-port=9010 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9010
    dst-port=9200 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9200
    dst-port=9600 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9600
    dst-port=8081-8082 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.0.30 to-ports=8081-8082
    dst-port=61616 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=61616
    dst-port=20000-30000 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.0.30 to-ports=20000-30000
    dst-port=9000 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9000
    dst-port=5080 in-interface=ether1 protocol=udp to-addresses=192.168.0.30 \
    to-ports=5080
    dst-port=554 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=554
    dst-port=40000-49999 protocol=tcp to-addresses=192.168.0.30 to-ports=\
    40000-49999
    dst-port=1883 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=1883
    dst-port=12366 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=12366
    dst-port=6379 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=6379
    dst-port=9400 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9400
    dst-port=9550 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9550
    dst-port=5060 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=5060
    dst-port=5672 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=5672
    dst-port=61613 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=61613
    dst-port=8161 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=8161
    dst-port=8080 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=8080
    dst-port=9500 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 \
    to-ports=9500
    dst-port=9900-9901 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.0.30 to-ports=9900-9901
    dst-port=36962 in-interface=ether1 protocol=tcp to-addresses=192.168.0.30
    dst-port=61001-65000 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.0.30 to-ports=61001-65000
add action=src-nat chain=srcnat disabled=yes src-address=192.168.0.30 \
    to-addresses=[Public IP]
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Re: Need help with port forwarding
Fri Jul 22, 2022 8:52 pm
For a Dahua NVR at one of my clients, I had to forward the following only:
TCP 443,554,37777
UDP 37778
Maybe check your NVR requirements again?
Tsatsralt
Mon Jul 25, 2022 4:13 am
Thank you for the suggestion.
I've asked Dahua support and configured as told. As you can see from the original post, I've configured the ports and still were unable to get video feed. I was successful at logging in to the NVR from the internet. Dahua support told me that I should check the network issue. So here I am.
Is there anything I've done wrong in the NAT? That's the question I have now.
I'll try the ports you've suggested and reply again.
Thanks again.
anav
Mon Jul 25, 2022 2:54 pm
Couple of Thoughts....
(1) Are you attempting to connect to a server, from users within the SAME LAN, and using the WANIP address of the router?
If so thats a hairpin NAT scenario and you will need to make a few changes.
(2) If you have external users to your Servers, do you have a firewall address list of these users to narrow down who has access?
By adding this, it makes the server NOT visible on scans of your ports.
Note: There is no excuse not to use a firewall address list as folks that have a dynamic WANIP can easily get free dyndns URLS to use with their WANIP and thus give you the dyndns URL and the MT router will resolve them correctly.
(3). The full config is required not just a snippet (minus any public IP info of course), to make any assessment of your setup.
Tsatsralt
Tue Jul 26, 2022 4:11 am
Hello.
I'm trying to give access to NVR to users who will use mobile client of the NVR(mostly will use mobile data).
I port forwarded 443 to public IP and can log in to NVR using mobile client. The problem is I can't watch video feed and playback recorded videos.
Also how can I get full config? As I mentioned before, I'm new to the Mikrotik.
anav
Tue Jul 26, 2022 4:36 am
Hello.
In winbox go to New Terminal and at the command line type
/export hide-sensitive file=anynameyouwant
Then go to winbox files, find the file created download it to your computer and the open it in notepad ++.
ensure no public WANIP or gateway information is presented and then copy it and paste it into
a post here, and use the code quote brackets to encapsulate the paste so its short and presentable. ( next to the Bold Italics to the right, the black square with white square brackets )
Tsatsralt
Tue Jul 26, 2022 11:29 am
Here is the config
# jul/26/2022 16:15:00 by RouterOS 6.49.5
# software id = Q7XR-8N6I
# model = RB4011iGS+
# serial number = D4440DFB53A7
add name=bridge1
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=WAN
add name=LAN
/ip firewall layer7-protocol
add name=DENIED regexp="^.+(facebook.com|youtube).*\$"
/ip ipsec peer
add address=(IPsec peer network) name="to APU Logistic"
add address=(IPsec peer network) name="to Capital house"
add address=(IPsec peer network) name="to APU Dairy"
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=3des hash-algorithm=\
    md5 name="to APU Logistic"
add dh-group=modp1024 enc-algorithm=3des hash-algorithm=md5 name=\
    "to Capital house"
    "to APU Dairy"
add dh-group=modp1024 enc-algorithm=3des hash-algorithm=md5 name="to Tiger"
    "to Shukhlai"
/ip ipsec peer
add address=(IPsec peer network) name="To Tiger" profile="to Tiger"
add address=(IPsec peer network) name="To Shunkhlai" profile="to Shukhlai"
/ip ipsec proposal
add auth-algorithms=md5 enc-algorithms=3des name="to APU Logistic"
add auth-algorithms=md5 enc-algorithms=3des name="to Capital house"
add auth-algorithms=md5 enc-algorithms=3des name="to APU Dairy"
add auth-algorithms=md5 enc-algorithms=3des name="to Tiger"
add auth-algorithms=md5 enc-algorithms=3des name="to Shukhlai"
add name=dhcp ranges=192.168.0.6-192.168.0.30
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add interface=ether1 list=WAN
add address=(public IP)/29 interface=ether1 network=(Hidden)
add address=192.168.0.1/27 interface=bridge1 network=192.168.0.0
/ip dhcp-client
add address=192.168.0.0/27 gateway=192.168.0.1 netmask=27
set servers=(DNS server 1),(DNS server 2)
/ip firewall address-list
add address=192.168.0.0/24 list=loc
add address=192.168.1.0/24 list=loc
add address=192.168.2.0/24 list=loc
add address=192.168.3.0/24 list=loc
add address=192.168.4.0/24 list=loc
add address=192.168.6.0/24 list=loc
add action=accept chain=forward dst-address=192.168.0.30 dst-port=443 \
add action=accept chain=forward dst-address=192.168.0.30 dst-port=9100 \
add action=accept chain=forward dst-address=192.168.0.30 dst-port=37777 port=\
    "" protocol=tcp
add action=accept chain=forward dst-address=192.168.0.30 dst-port=37778 \
    protocol=udp
add action=accept chain=forward disabled=yes dst-address=192.168.0.30 \
    dst-port="" in-interface=ether1 protocol=tcp
add action=accept chain=forward dst-address-list=loc src-address-list=loc
add action=masquerade chain=srcnat disabled=yes out-interface-list=WAN \
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=15455 \
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=9100 \
add action=dst-nat chain=dstnat disabled=yes dst-address=(Public IP address) \
    to-ports=80
    to-ports=9090
    to-ports=9010
    to-ports=9200
    to-ports=9600
    to-ports=61616
    to-ports=9000
    to-ports=5080
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=554 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 to-ports=554
    40000-49999
    to-ports=1883
    to-ports=12366
    to-ports=6379
    to-ports=9400
    to-ports=9550
    to-ports=5060
    to-ports=5672
    to-ports=61613
    to-ports=8161
    to-ports=8080
    to-ports=9500
    to-addresses=(Public IP address)
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=37777 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.0.30 to-ports=37777
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=37778 \
    in-interface=ether1 protocol=udp to-addresses=192.168.0.30 to-ports=37778
/ip ipsec identity
add peer="to APU Logistic"
add peer="to Capital house"
# Suggestion to use stronger pre-shared key or different authentication method
add peer="to APU Dairy"
add peer="To Tiger"
add peer="To Shunkhlai"
/ip ipsec policy
set 0 disabled=yes
add dst-address=192.168.0.160/27 peer="To Shunkhlai" proposal="to Shukhlai" \
    src-address=192.168.0.0/27 tunnel=yes
add comment="APU Logistic" dst-address=192.168.0.96/27 peer="to APU Logistic" \
    proposal="to APU Logistic" src-address=192.168.0.0/27 tunnel=yes
add comment="Capital house" dst-address=192.168.0.32/27 peer=\
    "to Capital house" proposal="to Capital house" src-address=192.168.0.0/27 \
    tunnel=yes
add comment="APU Dairy" dst-address=192.168.0.64/27 peer="to APU Dairy" \
    proposal="to APU Dairy" src-address=192.168.0.0/27 tunnel=yes
add comment="APU Dairy" dst-address=192.168.0.128/27 peer="To Tiger" \
    proposal="to Tiger" src-address=192.168.0.0/27 tunnel=yes
add distance=1 gateway=(Gateway)
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Ulaanbaatar
/system identity
set name="PSG ShUT"
anav
Tue Jul 26, 2022 3:53 pm
(1) This seems rather odd, (27 vice 24) but assuming you know what you are doing.
(2) Also no idea what you are doing within ipsec policy.......
(3) What is weird is a ref to local for IP addresses that seem to have no attachment to anything.......
They are noted in this rule.......... which makes no sense either ???
and noted again here........ very confusingl.
(4) Is this router facing a public IP address aka the internet, if so the rules are missing many needed things and you should NOT have this plugged into the internet until fixed.
(5) WHy do you have port forwarding (dst-nat rules) in the FORWARD CHAIN??
You only need on rule in the forward chain to permit port forwarding in general.
"" protocol=tcp
protocol=udp
(6) Format for port forwarding is incorrect,
Basically if you have a fixed WANIP aka static, then this works
If you have a dynamic WANIP, the this is typical
add action=dst-nat chain=dstnat in-interface=ether1 dst-port=15455 \
Tsatsralt
Wed Jul 27, 2022 4:19 am
Hello
From 1 to 3 and 5, we connected few sites to main site using ISP's tunnel and ISP's engineer helped to connect these branch sites. I didn't do the config at that time.
As for the number 4, yes this is internet facing router. If you have an suggestion please tell me? I really appreciate your support.
Also I deleted those Firewall filters which addressed to 192.168.0.30
6, I tried few thing when we faced an problem on NVR. I'll fix the structure.
Thank you.
anav
Wed Jul 27, 2022 3:55 pm
Advice for firewall rules........
viewtopic.php?t=180838
Advice for port forwarding.......
viewtopic.php?t=179343
Tsatsralt
Thu Jul 28, 2022 5:26 am
@anav
Thank you go the advice.
I followed the port forwarding topic and configured Filter and NAT rules. Cleaned up an unnecessary rules.
Even though I followed the topic, I might have made some mistake or something because I still can't see the video feed.
Could you look at config, please?
# jul/28/2022 10:07:52 by RouterOS 6.49.5
add name=bridge1
add name=WAN
add name=LAN
/ip ipsec peer
add address=(IP-sec peer IP) name="to APU Logistic"
add address=(IP-sec peer IP) name="to Capital house"
add address=(IP-sec peer IP) name="to APU Dairy"
/ip ipsec profile
    "to Capital house"
    "to APU Dairy"
    "to Shukhlai"
/ip ipsec peer
add address=(IP-sec peer IP) name="To Tiger" profile="to Tiger"
add address=(IP-sec peer IP) name="To Shunkhlai" profile="to Shukhlai"
/ip ipsec proposal
add address=(Public IP address) interface=ether1 network=(Network IP)
/ip dhcp-client
set servers=202.131.224.2,202.131.232.4
add action=accept chain=forward connection-nat-state=dstnat
add action=src-nat chain=srcnat out-interface=ether1 to-addresses=\
    (Public IP address)
add action=dst-nat chain=dstnat dst-address=(Public IP address) dst-port=16544 \
    protocol=tcp to-addresses=192.168.0.11 to-ports=3389
/ip ipsec identity
add peer="To Tiger"
/ip ipsec policy
set 0 disabled=yes
    tunnel=yes
add distance=1 gateway=(Gateway address)
/ip service
/system clock
/system identity
set name="PSG ShUT"
From what I roughly understand is I can log into the NVR from internet. When I try to watch video feed, client program (NVR's) says "server connection failed", so there must be some miscommunication thing is going on like NVR sends packet to client but client can't recognize the source address.... maybe.
Thanks again :D
anav
Thu Jul 28, 2022 3:21 pm
Nothing springs out at the moment......
But lets look at your sourcenat rules
(Public IP address)
The last rule is NOT required, the destination-nat rules seem correct, and the sourcenat rule using firewall address lists makes no sense to me,...
Try this........ (remove the last two rules).
(Public IP address)
If you are attempting to access the NVR from within the server, you would be running into loop back and would need this additional rule.
add chain=srcnat action=masquerade dst-address=192.168.0.0/27 src-address=192.168.0.0/27
Users browsing this forum: andrep, boocko, Google Adsense [Bot], mtkvvv and 49 guests
