wolfeyes
Static routing within ovpn server bridge
Fri Jul 22, 2022 12:08 pm
I need your help on the following routing use case:
I've set up an openvpn router with a couple of connected remote users on the same bridge.
Behind the connected ovpn clients mt routers, there some additional subnets that I need to get access from the ovpn bridge subnet.
Windows PC: 192.168.110.23 ---> MT ovpn router 192.168.110.1 <------- MT ovpn client 192.168.110.60 (with subnet 192.168.14.0/24) <------ host 192.168.140.10
CONFIG 1:
So for the PC to access host 192.168.140.10, I've added a static route on the MT ovpn server:
add distance=1 dst-address=192.168.140.10/32 gateway=192.168.110.60
The traceroute on the Windows PC is as follows:
C:\Users\user>tracert -d 192.168.140.10
Tracing route to 192.168.14.10 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.110.1
2 10 ms 14 ms 14 ms 192.168.110.60
3 14 ms 16 ms 7 ms 192.168.140.10
Trace complete.
With this config, ping icmp is working. BUT tcp is not working. Wireshark traces reveal TCP retransmissions.
Then I managed to follow another approach by adding the static route on the windows pc.
CONFIG 2:
C:\Windows\system32>route add 192.168.140.10 mask 255.255.255.255 192.168.110.60
OK!
C:\Windows\system32>tracert -d 192.168.140.10
Tracing route to 192.168.140.10 over a maximum of 30 hops
1 7 ms 7 ms 7 ms 192.168.110.60
2 8 ms 7 ms 7 ms 192.168.140.10
Trace complete.
Now with this approach, TCP is also working with success. But the traffic is not passing from the MT ovpn router.
However I need to avoid adding static routes on the various PCs and server. How can this be resolved on the MT ovpn router?
Users browsing this forum: No registered users and 17 guests
