doush
Long time Member
Long time Member
Feature Request: Multiple RADIUS Profiles
Fri Jul 22, 2022 12:18 pm
In RouterOS, we need to be able to define different Radius Servers per PPP Profile or PPPoE Server.
Nearly all other vendor products allow this and is a must-have feature.
It would have been nice if this option is presented in PPP-Profile configuration so we can define specific RADIUS servers per PPPoE Service.
doush
Long time Member
Long time Member
Re: Feature Request: Multiple RADIUS Profiles
Sat Jul 30, 2022 11:32 am
It is really interesting that no body actually supports this idea.
It is absurd that we are forced to use a single RADIUS server per router/service.
loloski
Sat Jul 30, 2022 11:53 am
i think this can be done with realm e.g username@domain1 when your radius server see the suffix @domain1 it will proxy the request to other different radius server, anyway i agree with you if this can be done in a per profile basis we also need this feature, but at this point stability on ROS v7 is currently their focus
blingblouw
Re: Feature Request: Multiple RADIUS Profiles  [SOLVED]
Sat Jul 30, 2022 12:16 pm
Are you saying you want different pppoe servers to auth via different radius servers? This can be done already.
Add your pppoe-server name as the "Caller-ID" of the radius server, then that pppoe-server will use that server.
example
/interface pppoe-server server
add authentication=pap default-profile=default disabled=no interface=\
    bridge-pppoe1 service-name=pppoe1
    bridge-pppoe2 service-name=pppoe2
/radius
add address=1.1.1.1 called-id=pppoe1 secret=RADIUSSECRET service=ppp timeout=3s
add address=2.2.2.2 called-id=pppoe2 secret=RADIUSSECRET service=ppp timeout=3s
loloski
Sat Jul 30, 2022 12:59 pm
oh that's great i didn't know that :) thanks for the heads up
rextended
Sat Jul 30, 2022 1:54 pm
In fact, this request and the complaint came from those who did not know how the software works ...
doush
Long time Member
Long time Member
Sat Aug 06, 2022 1:09 pm
Perfect, I didint know that was possible.
Thanks for the info.
Users browsing this forum: No registered users and 7 guests
