Hi all,
I am about to add a second Internet line to my home so I can have a back up Internet line. I was wondering what small router can I use to manage the two WAN connections.
The hEX family looks good for the job, however I have some doubts. For instance, If I get a hEX S, Can I use two Ethernet ports as a WAN or the unique ports available for WAN son the SPF port and the first Ethernet port? On the other hand, the hEX model seems to accomplish the requirements but it only has one WAN port, or can I use any port as a WAN?
If none of the hEX family routers can do the job I think RB2011 family will do, The counter part here is those 5 Fast Ethernet ports.
Any help on this?
Thank you.
