tom65
IP firewall connection
Fri Jul 22, 2022 9:48 pm
In /ip firewall connection
I would like to retrieve only "reply packets" value and store into variable.
For the life of me I cannot get it done, no "get" option.
With this I will be able to complete my script.
Kind regards...
rextended
Re: IP firewall connection  [SOLVED]
Fri Jul 22, 2022 11:40 pm
what did you write???
:local variable [/ip firewall connection get ([find where timeout>10s]->0) value-name=repl-packets]
:put $variable
tom65
Sat Jul 23, 2022 7:27 am
:put $variable
Thanks for reply.
The aim is to store reply packets of all sip connections and check every "some" interval if the count is increased. If not, remove connection for that IP. This is for extensions that connect to cloud PBX.
In South Africa we have intermittent outages (internet) where the extension loses its registration with the PBX (UDP) and then still tries to use the old connection track entry which does not work. Clearing this track entry forces a new track entry and the registration is then successful.
Users browsing this forum: abbio90 and 73 guests
