kabrutus
CubeSA 60Pro ac as Access Point and Station?
Fri Jul 22, 2022 10:31 pm
I purchased a few CubeSA 60Pro ac for an event i am doing. The event is not large in size, maybe max distance is 900'. Can i use the CubeSA 60Pro ac as the Access point and the stations on a PTMP application?
Or is the CubeSA 60Pro ac strictly an access point sector and will need to use the Cube 60Pro Ac or nRay as the stations?
I couldn't find what stations to use on the CubeSA 60Pro ac other than nRay on the site.
thanks
Bruzxce
Re: CubeSA 60Pro ac as Access Point and Station?
Sat Jul 23, 2022 10:02 am
CubeSA ProAc has it 60 beam width and it comes with l4 license so you can use it AP or Station and alll 60ghz cpe are backwards compatible.
Use CubeSA as AP to do PTMP because it has the 60Deg Beam Width then use Nray as station.
kabrutus
Sun Jul 24, 2022 6:44 pm
So if i use the CubeSA as an AP and a Station, will i still get the 600 meters of distance?
Bruzxce
Mon Jul 25, 2022 11:27 pm
as per the data sheet of the mikrotik atleast 800meters LOS and up to 8 Station.
chechito
Mon Jul 25, 2022 11:36 pm
always take published max distances "with a grain of salt"
If I have to take responsibility of the stability and performance of the solution i always assume half the published max distance
prague
Wed Aug 17, 2022 1:29 am
I tried. Max 300m with 3cpe 1 ap. 40 signal -66 rssi and many disconnects if one of drop from ap.
DeDMorozzzz
Wed Aug 17, 2022 2:34 pm
Does CubeSA supports 66960Mhz?
anav
Fri Aug 19, 2022 4:44 pm
I dont understand the question, I thought the 60hz cube stuff was simply an ethernet extension via wifi.
PlugNplay 1gig link between source cube at A. and receiving cube at B.
Further there is the option to get the source cube at A. with a wide beamwidth to allow ptp to several type B cube receiving units.
My perception was that one could attache whatever device to cube B to pass on traffic.
Local WIFI via 5ghz for example or to a switch etc....
In other words, no such talk of station or nray or anything, its a 1gig etherFI path LOL.
rextended
Fri Aug 19, 2022 5:20 pm
The 60GHz have various channels limited for each country.
Canada is the best coun... (anav???...)
Canada is the country with less power limits and more channels.
You can put on same pole 4 devices as AP, with different channel eachone, and you can reach 32 clients on 60°
DeDMorozzzz
Sat Aug 20, 2022 3:50 am
32 clients? Doesn't it support only 8 nowdays?
rextended
Sat Aug 20, 2022 9:15 pm
It's as if you can't read or don't understand what I've written.
DeDMorozzzz
Mon Aug 22, 2022 3:48 pm
my mistake
Users browsing this forum: No registered users and 8 guests
