satish
How to enable user using script when it is disabled
Sat Jul 23, 2022 1:16 pm
Hi friends,
I have one CCR 1009 device. In that i have a user 1 & user 2 with full access.
User2 is disabling user1. But i need a script which will check in a particular time interval for disable. if that(user1) is disable need to re-enable using that script.
Kindly help. Thanks in advance.
BrookXVll
Re: How to enable user using script when it is disabled
Sat Jul 23, 2022 1:46 pm
:local userName "userName"
:local disabledStatus []
:set disabledStatus [user get [find name=$userName] disabled]
:if ($disabledStatus) do={
    /user set $userName disabled=no
    :log info "User $userName is enabled"
rextended
Sat Jul 23, 2022 3:15 pm
for time interval, simply use the scheduler to launch the control at a given time
/user enable [find where name="user1" and disabled=yes]
if you want log also when the user is enabled (and not everytime if is enabled or not)
:local user "user1"
/user
:if ([:len [find where name=$user and disabled=yes]] > 0) do={
    enable [find where name=$user]
    :log info "User $user enabled again"
if you want continuosly check, but activate on given time interval (do not overlap with midnight!!!)
without logging
:local user     "user1"
:local timefrom "14:00:00"
:local timeto   "18:00:00"
:local now [/sys clock get time]
:if ( ([:totime $timefrom] < $now) and ($now < [:totime $timeto]) ) do={
    /user enable [find where name=$user and disabled=yes]
with logging
:local user     "user1"
    /user
Users browsing this forum: Kanzler, ko00000000001, nichky and 16 guests
