oguruma
Mikrotik LtAP: No internet
Sun Jul 24, 2022 5:49 am
I'm getting started with a Mikrotik LtAP6. Reset to factory defaults. AT&T SIM card (verified it works in an AT&T compatible tablet) inserted into Slot 2.
Mikrotik UI shows the signal strength and AT&T as the carrier.
I cannot ping 8.8.8.8 from any interface.
Logs shows "lte registered home"
What do I need to configure for this to work?
holvoetn
Re: Mikrotik LtAP: No internet
Sun Jul 24, 2022 7:43 am
Did you use Quickset to perform the very first config ?
Best to export config, post here between code quotes (after additionally reviewing the output for private info like passwords, public IP, etc.)
conectandonet
Sun Jul 24, 2022 7:48 am
Do a trace route (Tools-->Traceroute) to 8.8.8.8 to see where it times out
oguruma
Sun Jul 24, 2022 8:33 am
# jan/02/1970 03:06:17 by RouterOS 7.4
# software id = 80QS-W6RL
# model = RBLtAP-2HnD
# serial number = zzzzz
add admin-mac=DC:2C:6E:AE:3D:A3 auto-mac=no comment=defconf name=bridge
/interface lte
# A newer version of modem firmware is available!
set [ find ] allow-roaming=no band="" name=lte1 network-mode=gsm,lte
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=outdoor mode=\
    ap-bridge ssid=MikroTik-AE3DA4 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] use-network-apn=no
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=lte1 list=WAN
    192.168.88.0
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
holvoetn
Sun Jul 24, 2022 8:37 am
Remove serial number please.
I'll have a look later.
No APN info from provider ?
holvoetn
Sun Jul 24, 2022 8:42 am
Can you also provide output from
/ip address print
/ip route print
holvoetn
Sun Jul 24, 2022 9:17 am
Is that config export complete ?
It looks like it was truncated at the end.
How is your device supposed to be connected to ISP ?
I will assume you need to get an IP from ISP and then continue from there.
Or is there pass-through mode involved (most likely not) ?
I am puzzled by the fact you have no APN info
(this is how my LTE section looks like: first definition of APN profile, then use that profile when setting up LTE interface)
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=free authentication=none default-route-distance=5 ip-type=ipv4 \
    name=FRFree use-network-apn=no use-peer-dns=yes
/interface lte
set [ find ] allow-roaming=yes apn-profiles=FRFree band="" disabled=no !modem-init mtu=1500 name=lte1 network-mode=\
    3g pin=<secret>
yet the part of /interface lte shows a remark a new firmware is available. Which would mean there is connection otherwise it could not check ? Still is possible since that modem is sitting before the router part, it makes direct connection.
/ip address print and /IP route print outputs will tell more ...
But as far as I know there should be some APN info with setting of default route. I guess that's why it doesn't work.
oguruma
Mon Jul 25, 2022 3:43 am
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS          NETWORK       INTERFACE
;;; defconf
0 192.168.88.1/24  192.168.88.0  bridge
Flags: D - DYNAMIC; A - ACTIVE; c, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS      GATEWAY  DISTANCE
DAc 192.168.88.0/24  bridge          0
holvoetn
Mon Jul 25, 2022 7:06 am
You're not getting an address.
What provider are you with for the SIM card ?
What APN info do they require (can be found on their website, I hope) ?
oguruma
Mon Jul 25, 2022 7:42 am
This is AT&T (in the U.S). Their website, doesn't specify anything about how to configure with none-phone/tablet modems.
https://www.att.com/support/article/wireless/KM1062162/
holvoetn
Mon Jul 25, 2022 9:04 am
According to that page you linked, APN has to be set to NXTGENPHONE
So:
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=NXTGENPHONE authentication=none default-route-distance=5 ip-type=ipv4 \
name=ATT use-network-apn=no use-peer-dns=yes
/interface lte
set [ find ] allow-roaming=yes apn-profiles=ATT band="" disabled=no !modem-init mtu=1500 name=lte1 network-mode=\
3g,lte pin=<fill in your pin>
holvoetn
Mon Jul 25, 2022 9:26 am
Adding:
since in your first post you say that SIM works in a AT&T compatible tablet, what are the APN settings on that device ?
Use the same settings.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], sebol1204 and 51 guests
