CC3N
Configuring a network using two RB4011iGS+RM routers which need to communicate via IP radio (two parts)
Sun Jul 24, 2022 8:00 pm
I need to implement the configuration for a network which will involve using two RB4011iGS+RM routers. I am currently in the process of 'bench testing' with the routers connected directly by an Ethernet cable.
kevinds
Long time Member
Long time Member
Re: Configuring a network using two RB4011iGS+RM routers which need to communicate via IP radio (two parts)  [SOLVED]
Tue Aug 02, 2022 4:41 am
Why are you using a duplicate IP in the network?
192.168.100.1 appears on two different routers, sometimes on the same network segment..
What does "IP Radio" mean? Do they function as Layer 1? Layer 2? Or Layer 3?
From your diagram, VLANs don't matter.. Are only access ports used?
Users browsing this forum: Majestic-12 [Bot], sebol1204 and 40 guests
