jwcn
Need help ASAP!!!!
Thu Sep 27, 2007 6:49 am
I have a simple question that has me stumped.
I have two gateways. I use a routing mark to mark one ip address on my LAN to go out a separate gateway then the other traffic.
Problem is, when the routing rule is in place I can't access the web interface of the device anymore.
What do I need to do so I can still access the device and have it go out it's separate gateway?
sariao
Re: Need help ASAP!!!!
Thu Sep 27, 2007 3:18 pm
place your configurations.
t3rm
Thu Oct 11, 2007 7:11 pm
Add your "device" network to routing list. Place it under your mark.
It should works.
:lol:
- Rio.Martin -
