jeffSWKS
Cisco to MikroTik Convertor Tool
Tue Jul 26, 2022 6:11 am
Hello.
we are changing over from Cisco 2911 router to MikroTik CCR1009 and I was seeing if there was a tool/convertor out there already that I can import the Cisco configuraiton to back MikroTik configuration?
Thanks heaps for helping
rextended
Re: Cisco to MikroTik Convertor Tool
Tue Jul 26, 2022 10:07 am
You know other brands that provide easy tools for migrate users from or to another competitor?
jvanhambelgium
Forum Veteran
Forum Veteran
Re: Cisco to MikroTik Convertor Tool  [SOLVED]
Tue Jul 26, 2022 10:57 am
In firewalling sure, Palo Alto "Expedition" (from another firewall vendor to Palo) or FortiConvert (from different other vendor to Fortinet)
In (multiservice) ROUTING not so common, because this is possible much more complex. That Cisco 2911 might be using features that Mikrotik does not even have so....
@jeffSWKS , perhaps best thing is to split the C2911 into chuncks and see IF and WHERE matches exist, but it will be a manual process.
Users browsing this forum: fxcd, tgkmilo, trmns and 49 guests
