dannyleroux3
IP Route Print where ...
Tue Jul 26, 2022 9:08 pm
Hi all,
Attempting to print routes which have / contains a certain AS Path but I am unable to on the latest ROS7.4.
On ROS6 it would have simply been something similar to: ip route print where bgp-as-path~"XXXXX\$", where "XXXXX" is the ASN.
The same is not available on ROS7.4. Is the feature note available yet or am I missing something?
Thanks.
Danny.
mrz
Re: IP Route Print where ...  [SOLVED]
Tue Jul 26, 2022 9:52 pm
ip route menu does not have protocol specific parameters. It should be used only for static route configuration and probably quick route view.
Use routing/route menu
dannyleroux3
Wed Jul 27, 2022 4:31 pm
Thanks for the response.
"routing route print where bgp.as-path~"xxxxx\$"" did the trick.
Appreciate the help.
Users browsing this forum: No registered users and 25 guests
