atomicduck
Optimal signal levels 2.4/5 GHz for multiroom setup
Wed Jul 27, 2022 12:55 pm
Hi all, I have a Capsman network with 13 CAP AC APs, 8 of which are in dry-board rooms + 5 CAP XL in warehouse halls. I have set up 2.4 GHz and 5GHz channels manually, and was careful to set 2.4 GHz channels not to overlap.
The question is how to set signal levels? - currently I have set signal levels as following:
2.4 GHz: 3dbi
5 GHz: 6dbi
Do you think this is a good approach? Lowering signal levels to facilitate easier switch over from AP to AP?
Ca6ko
Long time Member
Long time Member
Re: Optimal signal levels 2.4/5 GHz for multiroom setup  [SOLVED]
Wed Jul 27, 2022 1:54 pm
The output power level of the access point is determined from the zone of its coverage, at the border of the zone should be -67 dB from the power depends on the size of the zone.
viewtopic.php?t=186228#p939655
atomicduck
Wed Jul 27, 2022 5:24 pm
Appreciated.
Users browsing this forum: Semrush [Bot] and 58 guests
