Using winbox I've going into my Firewall area then NAT and set up a dstnat rule where I set:
protocol to 17 (udp)
dst port to 123
and for action I set it to dst-nat
and set the to addresses as 192.168.25.22 (the ip address of my ntp server)
Then from a windows machine I try and have it update from time.windows.com, but it fails.
I set up a log for the rule and can see it is triggered with the message:
Code: Select all
dstnat: in:bridge out:(unknown 0), src-mac 7c:c3:a1:b7:35:fe, proto UDP, 192.168.25.48:53409->17.253.126.125:123, len 76
