ashpri
Where do I change path cost for RSTP
Fri Jul 29, 2022 4:25 am
In the following topology, where do I change the path cost for RSTP?
Do I change the path cost on the switch side A & D, or on the SXT side B & C?
Thank you.
chechito
Re: Where do I change path cost for RSTP
Fri Jul 29, 2022 4:30 am
example:
add bridge=brdge1 interface=ether1 path-cost=4
https://help.mikrotik.com/docs/display/ ... e+Protocol
ashpri
Fri Jul 29, 2022 5:11 am
example:
Thank you, I know how to change it. My question is WHERE should the change be. The switch port to the SXT or the wlan port of the SXT.
Users browsing this forum: gigabyte091, Google [Bot] and 85 guests
