oguruma
LTE: Mobile and stationary antennas?
Fri Jul 29, 2022 8:46 am
I'd like to add an LTE router to my RV with both a mobile antenna (more streamlined, less windload) and a directional fixed antenna on a mast. The mast would be erected when I arrive at the campsite, and the mobile antenna would be used when I'm on the road or for shorter stops.
I'd either use a coaxial switch to select the different antennas, or just screw/unscrew the connectors.
Can somebody recommend both/either a good mobile antenna for those two different use cases?
I have the MikroTik mANT LTE 5o. In my (very limited) testing, it didn't provide a noticeable improvement, neither in terms of signal indicators on the MT router, nor speed tests, versus the antenna on my LtAP.
krafg
Re: LTE: Mobile and stationary antennas?
Tue Aug 02, 2022 4:30 am
Check my signature.
Regards.
Users browsing this forum: Ahrefs [Bot], DimoSK and 18 guests
