user18273
Slow speed (WiFi/LTE)
Fri Jul 29, 2022 3:04 pm
i'm trying to find out where is the problem. I always have very bad speeds over Mikrotik. Can't understand is it WiFi or is it LTE.
The fact is that my macbook, never connects to 5ghz network.
I've read FAQ here in forum, found the problem about "Preambule-mode", find this setting in my mikrotik, but it is set for "both" as described in FAQ, but anyways my macbook never connects to 5GHz network.
p.s. i forgot to put a Windows PC (in the same room as Mikrotik and macbook), using 2.4GHz WiFi, i never ever had more then 5MBps Download :|
Any ideas how to sort it out?
holvoetn
Re: Slow speed (WiFi/LTE)
Fri Jul 29, 2022 3:11 pm
Have you tried connecting PC directly to MT to see what speedtest gives then ?
Without crystal ball ? No ...
:lol:
From terminal:
Review file, remove serial, remove public IPs, secret keys, ...
Then post contents between [code] quotes so we can review where potential problems might be.
user18273
Fri Jul 29, 2022 3:49 pm
:lol:
:D pity i don't have crystal ball :D
at the moment i dont have USB to LAN, to try directly from MAC, so i've tried from Windows PC:
WiFi 2,4GHz: Down 28, up 13
LAN: Down: 55, up 4 :)
# jul/29/2022 15:17:13 by RouterOS 6.49.2
# software id = 26W0-YUBZ
# model = RBwAPGR-5HacD2HnD
# serial number = xxx
add admin-mac=xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] allow-roaming=no name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
country=lithuania disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=. wireless-protocol=802.11 \
wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=lithuania disabled=no distance=indoors \
frequency=auto installation=indoor mode=ap-bridge ssid=.. \
wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] name=internet.tele2.lv
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.xx.150-192.168.xx.254
add address-pool=dhcp disabled=no interface=bridge lease-time=20h10m name=\
defconf
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
add address=192.168.xx.1/24 comment=defconf interface=bridge network=\
192.168.xx.0
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.xx.199 client-id=1:e4:5f:1:a3:6e:a mac-address=\
xx:xx:xx:xx server=defconf
add address=192.168.xx.188 client-id=1:e4:5f:1:a3:6e:2 mac-address=\
add address=192.168.xx.0/24 comment=defconf gateway=192.168.xx.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.xx.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes port=20202
set www-ssl certificate=192.168.xx.1 disabled=no port=21212 tls-version=\
only-1.2
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Riga
/system identity
set name=MikroTikLTE
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set port=lte1 receive-enabled=yes
BrateloSlava
Fri Jul 29, 2022 4:15 pm
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
This (wpa-psk) is probably not needed.
My "basic" settings for WiFi on this AP is:
/interface wireless set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=2ghz-g/n channel-width=20/40mhz-XX country=ukraine distance=indoors frequency=auto frequency-mode=superchannel hw-protection-mode=rts-cts mode=ap-bridge scan-list="" ssid=MikroTik wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/interface wireless set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=ukraine distance=indoors frequency=auto frequency-mode=superchannel hw-protection-mode=rts-cts mode=ap-bridge scan-list="" ssid=MikroTik wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
You need to change "country" and "superchannel".
Maybe you find, what LTE band are supported by operator. And set it in AP, like this:
/interface lte apn set [ find default=yes ] ip-type=ipv4 use-network-apn=no
/interface lte apn add apn=internet ip-type=ipv4 name=kyivstar use-peer-dns=no
/interface lte set [ find ] allow-roaming=no apn-profiles=kyivstar band=3,7,8 name=lte1 network-mode=lte
I'm use the latest ROS and firmware - "R11e-LTE6_V033" .
user18273
Fri Jul 29, 2022 5:08 pm
Thank you:
1. wpa1 removed.
2. what is wrong with country, what is it correct to set?
3. What is superchannel, how to set correctly? :)
4. How do i find supported LTE channels?
BrateloSlava
Fri Jul 29, 2022 5:27 pm
Try to set the settings like mine. Only in them you should change the country to "your own", etc.
My mobile operator is Kyivstar. This is how I asked Google: "Kyivstar lte band". :D
P.S.
In your configuration file, I saw the "country" parameter. If that correct - than search by "lithuania lte bands"...
user18273
Fri Jul 29, 2022 5:49 pm
i found this site: https://www.cellmapper.net
it shows bands for each tower. Adjusted my Mikrotik, but it does not helped with speed :|
p.s. i found where SuperChannel can be set. I've changed country, for some reason while selected Lithuania, it does not let me to choose. Anyways, i've change to Ukraine, then set superchannel, but it did not helped for the speed :|
That's very strange. My iphone gets double speed at the same location...
holvoetn
Fri Jul 29, 2022 6:18 pm
Latest is V034.
Updated my SXT (remotely) this week. Perceived speed may be a tad faster but could be me wanting it to be like that :D
As usual, no change log or added info.
@user18273, you may want to look into upgrading that part as well.
user18273
Fri Jul 29, 2022 7:50 pm
Latest is V034.
This is very strange. I see absolutely different firmware number. Mine is this:
Installed Version 6.48.6
Latest Version 6.48.6
holvoetn
Fri Jul 29, 2022 8:11 pm
Interfaces
Lte
Check firmware
Lte firmware is something else then ROS version.
user18273
Fri Jul 29, 2022 10:45 pm
Interfaces
Lte
Check firmware
Brilliant!!
R11e-LTE6_V025
But how to update it ?
user18273
Fri Jul 29, 2022 11:01 pm
OMG... i so dumb today...
it took me that long to understand what is this "2nd" firmware....
...i definitely need to go to holidays :)
thanks guys, going to update it..
BrateloSlava
Fri Jul 29, 2022 11:02 pm
Users browsing this forum: No registered users and 85 guests
