volkirik
bugfix script for ROSv7 PPPoE-Client
Fri Jul 29, 2022 7:29 pm
we are running WISP setup with ROSv7.5beta4 running on both PPPoE server and PPPoE clients.
if wlan1 goes down, pppoe client also goes down but its ipv4 address stays in /ip address menu as stuck...
so we wrote a script to remove dublicate address to prevent "error: could not add address: already have such address (6)"
:local interfaceName
:set interfaceName [/interface get $interface name]
:if ( [ :len ($"local-address") ] <= 0 ) do=\
  :log info "PPP removestuckadr: empty local address (down), checking if its stuck"
} else=\
  :log info "PPP removestuckadr: local address was ($"local-address") (down), checking if its stuck"
:local stuckadrId
:set stuckadrId [ find interface="$interfaceName" ]
#check if address still exists
:if ( [ :len $stuckadrId ] > 0 ) do=\
  :log info "PPP removestuckadr: removing stuck IPv4 address of $interfaceName"
  remove $stuckadrId
I hope you can benefit from this script, would be useful if you run WISP setups based on ROSv7.
please add script's name to PPP profile's on-down textarea. so it can be auto-run.
rextended
Re: bugfix script for ROSv7 PPPoE-Client
Fri Jul 29, 2022 8:52 pm
What is "WISP Setup"?
Why you use beta on device that serve your customers?
:local interfaceName [/interface get $interface name]
:local ladd $"local-address"
:if ([:len $ladd] <= 0) do={
} else={
    :log info "PPP removestuckadr: local address was $ladd (down), checking if its stuck"
:local stuckadrId [find where interface=$interfaceName]
:if ([:len $stuckadrId] > 0) do={
    remove $stuckadrId
Jotne
Fri Jul 29, 2022 10:54 pm
rextended
Fri Jul 29, 2022 11:09 pm
@Jotne... I'm a WISP...........
chechito
Fri Jul 29, 2022 11:47 pm
is not absolutely clear, but i think in this case WISP setup from client perspective refers to using Wireless interface as a cliente to connect to WISP infrastructure
this topic is a clear example why beta versions of software cannot be blindly deployed to production
this topic best fit on official topic of 7.5 beta release
viewtopic.php?t=187950
Users browsing this forum: pandared and 13 guests
