zorrua
Problems with ROS 7.4 in SXT 5HPnD
Sat Jul 30, 2022 11:27 pm
I try the 7.4 RouterOS in 2 P2P SXT 5HPnD devices.
They are not rock solid since I upgrade, the ping is getting big values and this is the proccessor and memory graph:
Imagev
And this is the voltage graph:
I upgrade the devices at 15:40.
Is something wrong with the new RouterOS version in this devices?
Kind regards.
krafg
Re: Problems with ROS 7.4 in SXT 5HPnD
Sun Jul 31, 2022 9:47 am
Can you back to ROS6?
Regards.
zorrua
Sun Jul 31, 2022 4:29 pm
Yes, I downgrade to v6, now all is working well.
I will keep in v6, the device are just to make the p2p wireless link.
Regards.
krafg
Sun Jul 31, 2022 7:32 pm
Great!
Thanks for the info.
My recommendation is wait some versions more to see how stable will be.
I'm not tested yet ROS7 but I prefer wait some more time.
Regards.
zorrua
Mon Aug 08, 2022 4:42 pm
Yes,
I will wait, but anyone has same problem? Just to know if it my problem or a global one?
Regards.
krafg
Thu Aug 11, 2022 6:27 pm
At least you can reconfigure your device with ROS7 to discard configuration problem/incompatibility. Remember do backup of your config.
Regards.
Users browsing this forum: No registered users and 112 guests
