Adamska
how to reset factory 1100 ahx2  [SOLVED]
Sun Jul 31, 2022 7:32 pm
Hi guys..
I search on net, yet couldn't find the answer and I hope it's not inappropriate.
Any ideas?
Much obliged
BrateloSlava
Re: how to reset factory 1100 ahx2
Sun Jul 31, 2022 7:37 pm
Adamska
Sun Jul 31, 2022 7:42 pm
Thanks, but the problem is I can't open the device so I'm looking for solution without that and unlillke ahx4 the reset button is in the router so...
I plugged and unplugged power several times too yet dlit didn't reset it...
Dude2048
Sun Jul 31, 2022 7:59 pm
You have to open it
holvoetn
Sun Jul 31, 2022 8:01 pm
If you can not open the device, you don't have access to reset.
So no reset.
Your choice what to do next.
Toggling power does never start a reset, or it would reset every time power is lost and back again and lost and ...
You have no possible means to access that device using winbox and MAC-access ?
Console access doesn't work either ?
BrateloSlava
Sun Jul 31, 2022 8:09 pm
Is the router case sealed with a warranty seal or what?
holvoetn
Sun Jul 31, 2022 8:19 pm
OK, that's a good one :lol:
In all seriousness, that device came out in 2011 (if the date on declaration of conformity can be used as base)
Has been discontinued since I don't know when (end 2017 ?).
A warranty seal should not be a problem, certainly not if the ONLY way to reset that device is to take of the lid.
Adamska
Sun Jul 31, 2022 8:41 pm
There was pre configuration with vlans and trunk and I didn't know about it (even now I have to figure it) but with all this the only option was reset factory so
Thanks everyone, much appreciated
Users browsing this forum: No registered users and 63 guests
