ErfanDL
How to disable udplite ?
Mon Aug 01, 2022 1:52 pm
Hi guys. how can I disable udplite in firewall service port ? when I try to disable udplite, show below error:
device is: RB2011UiAS-2HnD
RouterOS: 7.4
thanks.
mrz
Re: How to disable udplite ?
Mon Aug 01, 2022 2:29 pm
by disabling connection tracking.
rextended
Mon Aug 01, 2022 2:34 pm
Ok, @mrz has replied to you...
But why does the text inside the image get ignored every time???
If can not be "individually disabled", can't be "individually disabled"...
Znevna
Mon Aug 01, 2022 3:37 pm
Not everyone understands english error messages.
rextended
Mon Aug 01, 2022 3:45 pm
Thanks :!: , I hadn't thought of that (even though I'm not a native English speaker).
holvoetn
Mon Aug 01, 2022 4:35 pm
OK (not being a native speaker myself) but ...
OP IS posting on a forum where English is used as only language (theoretically, I've already seen other languages being used ...)
and
he writes his post in English ?
So even if he is not a native English speaking person, he understands enough or uses some translation tool which could also be used for that same error message.
He's already at 360 posts ...
That argument doesn't hold, I would think ... and otherwise you're being your sarcastic self again :lol:
(in case the message doesn't transfer: IT'S A JOKE)
ErfanDL
Mon Aug 01, 2022 4:55 pm
I was just looking for a solution to disable the udplite. what is all this discussion for? :|
Znevna
Mon Aug 01, 2022 4:58 pm
ErfanDL
Mon Aug 01, 2022 5:02 pm
I did this, but udplite was not disabled.
mrz
Mon Aug 01, 2022 5:04 pm
m? if you disable connection none of the helpers will work, because they depend on connection tracking.
ErfanDL
Mon Aug 01, 2022 5:05 pm
thanks for reply.
So the only way to disable udplite is to use the firewall rule.
Znevna
BOY! .. this one...
BrateloSlava
Mon Aug 01, 2022 6:37 pm
I also became interested. And I decided to turn it off.
Config:
[removed]
Where is the mistake?
Attempts to disable one at a time or all at once - the result is the same.
Reason: [removed] all screenshots
rextended
Mon Aug 01, 2022 6:47 pm
There is no mistake: can't be disabled.
When "red" are not active (I = Invalid)
You can not visually disable that on any way
But when conntrack is (forced)off, the 3 items are red because are not active (I = Invalid).
jvanhambelgium
Forum Veteran
Forum Veteran
Mon Aug 01, 2022 6:57 pm
On my RB5009 / 7.3.1 all of them are disabled (already a long time) and Connection Tracking for sure is active!
rextended
Mon Aug 01, 2022 6:59 pm
Is only visual
try to "disable" and enable it again....
In a nutshell, to see them "deactivated" visually, install or downgrade to 7.0.9,
then deactivate them,
then upgrade to 7.4,
but you can no longer reset the machine, as you do they "reactivate".
But internally on 7.1+, visaully disabled or not, still active.
Users browsing this forum: dsfak, martidim, philipwillemse, tangent and 198 guests
