aSelfLion
Mikrotik routerboard 1036 hotspot, Users, User Profiles, Active, Host, ip Bindings How can I draw tables with Ms Excel e
Mon Aug 01, 2022 5:11 pm
How can I draw tables with Ms Excel e Vba?
BrateloSlava
Re: Mikrotik routerboard 1036 hotspot, Users, User Profiles, Active, Host, ip Bindings How can I draw tables with Ms Exc
Mon Aug 01, 2022 6:14 pm
What does your question have to do with the problems of the devices of this manufacturer? Or to the difficulties with setting it up.
rextended
Mon Aug 01, 2022 7:28 pm
The user ask how to draw µ$oft Ex¢el table$, with Vi$ual Ba$i¢ for Appli¢ation$,
using as data source the user-manager database.
But he can't ask it correctly.
aSelfLion
Tue Aug 02, 2022 11:53 am
Hello again
All I want is to import active users in Mikrotik Hotspot into Excel table.
Being able to connect and pull this with excel vba.
accarda
Tue Aug 02, 2022 12:07 pm
You can have a look at how to use API to communicate with router and send your queries to receive the needed data:
https://help.mikrotik.com/docs/display/ROS/API
There is also some example using Python, which has lot of functions to manage Excel and PDF files:
https://help.mikrotik.com/docs/display/ ... n3+Example
There is also REST-API that you can check:
https://help.mikrotik.com/docs/display/ROS/REST+API
aSelfLion
Tue Aug 02, 2022 12:18 pm
Thank you. I will try.
If you know of any other examples, I would appreciate if you could share them.
accarda
Tue Aug 02, 2022 12:26 pm
Personally I have never used API approach as I mostly do all my stuffs with script directly on router.
However one thing you could also check is, if it fits your needs, an easy way to generate a sort of CSV file generated with a ROS script after that you have gathered the user information that you are looking for.
I'm not used to user management topics, so I don't know what options you have, but whatever can be scripted, then you can save such data directly to a file in CSV and then use Excel to import such file directly some way.
Options are there, you can choose the best for you.
aSelfLion
Tue Aug 02, 2022 4:59 pm
Yes.
As you said, I can export to csv file and export it to excel. Let me work a little.
Thank you for your reply.
Users browsing this forum: actomobile, Gianna99, jbolakakis and 114 guests
