mafiosa
Leaking ospf routes between VRFs
Tue Aug 02, 2022 6:50 am
Is there any guide for leaking routes learnt from OSPF on VRF A to VRF B?
mrz
Re: Leaking ospf routes between VRFs
Tue Aug 02, 2022 4:27 pm
You can try two OSPF instances and redistribute routes from one instance to another.
mafiosa
Wed Aug 03, 2022 3:56 pm
A simple config example would be really helpful.
mafiosa
Thu Aug 04, 2022 1:24 pm
????? no guide or example?
joegoldman
Forum Veteran
Forum Veteran
Thu Aug 04, 2022 1:34 pm
You've been given the idea, use documentation to go have a go yourself. If you'd like someone to consult for you reach out to some consulting businesses so they can provide config for you to use.
Users browsing this forum: No registered users and 46 guests
