lugonzal
LtaP mini, metarouter booting status
Tue Aug 02, 2022 1:38 pm
Hey folks,
I'm trying out to set-up a metarouter on the LtaP and the metarouter it gets stuck on booting state.
Is the ltaP capable of creating a metarouter or Im just messing around.
Kind regards
rextended
Re: LtaP mini, metarouter booting status
Tue Aug 02, 2022 2:16 pm
With only 2M of storage free?
lugonzal
Wed Aug 03, 2022 10:30 am
I'm a newbie, with 2MB free you mean in the LtaP mini, or the virtual machines?
What I get in the output of /metarouter print
[xxxx@MikroTik] > /metarouter print
Flags: X - disabled
# NAME-------------------------------------------------------------------------------------------------------------------------MEMORY-SIZE--DISK-SIZE----USED-DISK STATE
0 mr0-----------------------------------------------------------------------------------------------------------------------------32MiB--------------32000kiB----------3kiB booting
rextended
Wed Aug 03, 2022 12:59 pm
/system resource print ?
lugonzal
Wed Aug 03, 2022 1:03 pm
uptime: 1m14s
version: 6.47.10 (long-term)
build-time: May/31/2021 09:54:59
factory-software: 6.44.6
free-memory: 40.5MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 650MHz
cpu-load: 13%
free-hdd-space: 3600.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 200
write-sect-total: 1063
bad-blocks: 0%
architecture-name: mipsbe
board-name: LtAP mini LTE kit
platform: MikroTik
rextended
Wed Aug 03, 2022 1:05 pm
lugonzal
Wed Aug 03, 2022 1:25 pm
By this, you meant that there is not enough storage for the Metarouter? In this case I must create one which fits the available memory?
Or should I, somehow , free used memory?
I tried to create a smaller Metarouter, but minimun memory-size must be 24MB.
Sorry for the question, but I would like to understand how to behave.
Thank you, rextended.
rextended
Re: LtaP mini, metarouter booting status  [SOLVED]
Wed Aug 03, 2022 1:43 pm
Like all the other RouterBOARD, all functions are available everywhere (some exception for architecture applied)
but on the other side, not on all devices you can use some services because storage or ram are not sufficient.
I do not think than 2/3MiB free NAND or Flash suffice for both metarouter and regular working of the routerboard.
lugonzal
Wed Aug 03, 2022 2:32 pm
Okey, I get it.
Thank you for your time rextended!!!!
Users browsing this forum: No registered users and 54 guests
