Hello forum,
I am trying to use my S109-8G-1S-2HnD-IN as a switch + WLAN.
All the VLANS gateway are not on the S109-8G-1S-2HnD-IN
I am using router on a stick setup, meaning i use a trunk port with tagged VLANS to feed the mikrotik the VLANS.
I want to use other ports as access port for one of the VLANs
I am using ether1 as unsigned VLAN7 as WAN, i am using ether2 as trunk for supplying the VLANS
ether3 untagged VLAN2
ether4 untagged VLAN7
ether5 untagged VLAN9
ether7 and ether8 untagged VLAN7
When i use my wired connection on the laptop i can connect to host connected to the S109-8G-1S-2HnD-IN.
When i disable wired connection and just use wifi i can connect to internet, but hosts connected by wire to S109-8G-1S-2HnD-IN cannot
Questions:
- How do i make internet connection possible for the VLANS with the current setup? So connectivity for VLAN7 to 192.168.7.1 | vlan 9 via 192.168.9.1
- I would like to know if its possible to let the wifi be enabled in VLAN7 so connectivity is transparent instead of natting from 192.168.88.0/24
- I am now using ether1 as WAN, and ether2 as trunk, is it possible to use 1 port for wan and trunk
Thx in advance for assistance
