autominus
Winbox not connecting to router
Thu Aug 04, 2022 10:30 am
I have MikroTik Cloud Core Router CCR1009-7G-1-1S+ and I have a problem.
I want to connect Mikrotik in topology:
I configured on the interfaces eth1, eth2, eth6, eth7 bridge with option "use ip firewall". When I connect ISP to eth1 and my test laptop to eth6 - this connection working fine.
But I can't connect via WinBOX on Layer 2 to the router.
My configuration:
# jan/01/2002 02:55:32 by RouterOS 6.48.6
# software id = M97P-GYJ9
# model = CCR1009-7G-1C-1S+
# serial number = 79AE06B460AE
add name=BridgeSecure
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=BridgeSecure interface=ether1
add bridge=BridgeSecure interface=ether2
add bridge=BridgeSecure interface=ether6
add bridge=BridgeSecure interface=ether7
/ip settings
set tcp-syncookies=yes
add address=192.168.88.1/24 comment=defconf interface=combo1 network=\
    192.168.88.0
/ip firewall address-list
add list=ddos-attackers
add list=ddos-target
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddos-target \
    address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers \
add action=jump chain=forward connection-state=new jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s \
    protocol=tcp tcp-flags=syn,ack
/ip firewall raw
add action=drop chain=prerouting dst-address-list=ddos-target \
    src-address-list=ddos-attackers
/ip ssh
set forwarding-enabled=remote
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/system routerboard settings
set auto-upgrade=yes
Thank you in advance for your help.
mkx
Re: Winbox not connecting to router
Fri Aug 05, 2022 10:30 pm
L2 connectivity doesn't work over routers (those work on L3).
Users browsing this forum: infospa, jaclaz, mattnl, Michiganbroadband, neki and 116 guests
