mafiosa
Redistribute other ospf equivalent in v7
Thu Aug 04, 2022 1:48 pm
What is the equivalent of redistribute other ospf in v7? I want to redistribute routes between two ospf instances on the same router.
mrz
Re: Redistribute other ospf equivalent in v7
Thu Aug 04, 2022 2:13 pm
Same as in v6. Is the redistribute=ospf not working?
mafiosa
Thu Aug 04, 2022 3:17 pm
No! I have set up in the following way:
/routing id
add disabled=no name=Home-Router-ID select-dynamic-id=only-loopback \
select-from-vrf=Home
/routing ospf instance
add disabled=no name=ospf-v2 redistribute=connected,ospf router-id=main \
version=2 vrf=main
add disabled=no name=ospf-v2-home redistribute=connected,ospf router-id=\
Home-Router-ID routing-table=Home version=2 vrf=Home
/routing ospf area
add area-id=0.0.0.0 disabled=no instance=ospf-v2 name=ospf-backbone-v2 type=\
default
add area-id=0.0.0.0 disabled=no instance=ospf-v2-home name=ospf-backbone-home \
type=default
Is it okay to leak routes between main and Home VRF?
Users browsing this forum: No registered users and 14 guests
