ashpri
WAN Load Balance question. WAN2 only to operate once WAN1 reaches X mbps..
Fri Aug 05, 2022 6:36 am
I've seen this discussed somewhere in the forum (or a MUM) but I have not been able to track it down.
I have successfully implemented WAN Load Balancing across 3 ISPs, with certain VLANs going out specific WANs and certain VLANs going out all 3 WANs.
My next goal is to try a scenario where WAN2 will only be used when WAN1 reaches say 100mbps.
Can anyone recommend a lead to start my research, either past forum links or MUM presentations or direct guides. Thank you.
tomaskir
Trainer
Trainer
Re: WAN Load Balance question. WAN2 only to operate once WAN1 reaches X mbps..  [SOLVED]
Tue Aug 09, 2022 5:49 pm
You can find a presentation on this here: https://youtu.be/67Dna_ffCvc
While the presentation itself is quite old, everything in it is fully applicable to what you need :)
anav
Tue Aug 09, 2022 6:30 pm
I usually link to this site, great presentation by some Thomas guy...... Looks older than the guy in the video though. ;-P
https://mum.mikrotik.com/presentations/US12/tomas.pdf
(Question to self: Why are there so many MT geniuses in the baltic/slavic area????)
Users browsing this forum: airbytes, Amazon [Bot], mquan1984 and 147 guests
