anv
Routing table not shown in ip/routes in 7.4
Fri Aug 05, 2022 1:32 pm
En 6.x versions in the ip/routes page there was a drop-down menu for choosing the routing table to show. In 7.4 routes can't be filtered by routing table and the routing table name is not shown on the list so it's not possible to know if a route is stored in main table or some alternative ones.
I also don't see the routing mark field.
mrz
Re: Routing table not shown in ip/routes in 7.4
Fri Aug 05, 2022 1:37 pm
Set show columns to show "routing table"
anav
Fri Aug 05, 2022 6:41 pm
Thanks!
But Perhaps it is a good time to point out that Routing Rules tab is missing. ;-)
Sob
Fri Aug 05, 2022 7:28 pm
It's not missing anymore, I found it in Routing->Rules, I'm pretty sure you'll find it there too. :)
As for quick filter that was in v6, it would be nice to have it back. Yes, it was duplicate functionality, but also very handy shortcut, because you had always visible dropdown, where you could select routing table you're interested in. You can get the same result using filter, but for that you have to click filter button, select "Routing Table" from long dropdown, select "is" from another, select routing table from third, and finally click "Filter". It takes too long.
anav
Fri Aug 05, 2022 10:25 pm
Where I am using 7.4 latest and there is no Rules Tab in IP routes in winbox..................
mrz
Fri Aug 05, 2022 10:36 pm
routing->rules
anav
Fri Aug 05, 2022 11:25 pm
Boy do I feel stewpid!! Who snuck in a Winbox Main Tab entry of Routing LOL.................
So Tricky !!
Okay so, I dont see firewall address lists as an entry argument for routing rules....................... GOTCHA !!!
aoakeley
Sat Aug 06, 2022 1:19 pm
I wish this column was shown by default......
But I guess other people want other defaults, so can't please everyone.
anav
Sat Aug 06, 2022 2:52 pm
Concur oakely, to me that was a glaring omission but easily rectified.
anv
Mon Aug 08, 2022 10:25 am
Where is "show columns"?
Users browsing this forum: No registered users and 61 guests
