vanikcz
MAC-Telnet SDK
Fri Aug 05, 2022 8:29 pm
Is there any (plan to) release SDK for MAC-Telnet?
Basically I want to create utility that can initialy set the router that was bought by customer.
Do you know about any other viable path to setup freshly purchased box without running winbox? Yes, I can use API, or SSH but MAC-Telnet might be cooler...
Best Regards,
Jan
Sob
Re: MAC-Telnet SDK  [SOLVED]
Sat Aug 06, 2022 1:01 am
I wouldn't expect much from MikroTik, they don't seem to be too keen on being open.
There's open source MAC-Telnet, which looked hopeless for a while, after MikroTik changed the protocol in 6.43 and refused to share details. But according to this comment, someone finally cracked it. It was not implemented yet, but the future looks a bit brighter.
Users browsing this forum: 8874479, Bing [Bot], Google [Bot], litogorospe and 104 guests
