Guscht
CRS328 / high CPU-Lod SPI
Sat Aug 06, 2022 10:32 am
does anyone know why the process "SPI" creates such a high CPU-Load? Sometimes it goes up to 100%
I have read this is LED related, but the CRS328 does not have a LED screen.
The config is 1:1 the same as on a replaced CRS326, this never showed SPI.
rextended
Re: CRS328 / high CPU-Lod SPI
Sat Aug 06, 2022 10:53 am
If I were an editor and someone asked me to evaluate which are the "slow" parts of the tale,
I wouldn't have at least the text to read???
Starting from the fact that you have censored a private IP in the 10.x.x.x/8 range, already tells me so much about your knowledge.
But a book by the cover should not be evaluated, NO?
Guscht
Sat Aug 06, 2022 1:36 pm
The question is, what is SPI at first? MT does not clarifiy?
https://wiki.mikrotik.com/wiki/Manual:Tools/Profiler
Normally SPI stands for "Stateful Packet Inspection" but this device is configured as a simple switch, no NAT, no filter, no mangel... So SPI must be something different. Maybe someone knows?
@rextended, why are you never give a sensible reply? Whats wrong to hide my exact private IP scheme? All information I give, is the device is configured in accordance to RFC1918. https://www.rfc-editor.org/rfc/rfc1918.html There is something like "Security through obscurity" https://en.wikipedia.org/wiki/Security_ ... _obscurity But I dont expect you know something.
rextended
Sat Aug 06, 2022 2:53 pm
Because you do not provide any sensible question?
If instead of wasting time unnecessarily obscuring 10.8x.x.x, and instead you published the export to see what made you "use" ( :twisted: ) the spi,
which maybe you hadn't noticed, it was better.
Surely hiding your internal private IP, which only you use in the world, is a matter of national security.
I forgot how important it is to keep that highly traceable IP hidden that other 1000 devices have.
rextended
Sat Aug 06, 2022 3:02 pm
I see that you have already searched in the past ...
viewtopic.php?t=179503
SPI = https://de.wikipedia.org/wiki/Serial_Pe ... _Interface
chechito
Sat Aug 06, 2022 5:37 pm
sometimes when there is a high activity over storage SPI shows high usage
Znevna
Sat Aug 06, 2022 9:23 pm
Provide a config export.
mada3k
Long time Member
Long time Member
Sat Aug 06, 2022 9:56 pm
As chechito says. The flash memory sits on the SPI-bus. Are you using the flash memory for something?
Users browsing this forum: andrep, gigabyte091, kolopeter, menyarito, Speedyboat13 and 93 guests
