reevansxyz
Redirect DNS, but with IPv6?
Sat Aug 06, 2022 6:19 pm
Greetings MikroTik fam,
As of the moment this is how I'm redirecting my IPv4 DNS to my router.lan @ 10.17.1.1 :
  add chain=dstnat dst-port=53 protocol=udp to-addresses=10.17.1.1 action=dst-nat comment="redirect DNS"
How may I replicate the above rule for IPv6?
Cheers,
Reev
sindy
Re: Redirect DNS, but with IPv6?  [SOLVED]
Sat Aug 06, 2022 6:42 pm
/ipv6/firewall/nat/add chain=dstnat protocol=udp dst-port=53 action=dst-nat to-address=2003:456:789::1/128
But the mandatory pre-requisite is to run a new enough release of RouterOS v7. There is no IPv6 NAT in RouterOS v6, nor in early versions of RouterOS v7.
reevansxyz
Sat Aug 06, 2022 6:54 pm
Heya there sindy,
Thank you for reaching out, P.S. I've never actually used RouterOS v6, the RB5009 that I recently got came with factory firmware RouterOS v7.1.3; where is 2003:456:789::1/128 coming from tho? Do I have to manually add that to the IPv6 address?
Regards,
Reev
sindy
Sat Aug 06, 2022 7:03 pm
The particular address is a random one, just formally correct, just as an example; the /128 has been added by RouterOS so it is present in the export, but I have entered the address without it.
reevansxyz
Sat Aug 06, 2022 7:13 pm
Brilliant, thanks a heap!
Users browsing this forum: nescafe2002 and 55 guests
