atul573
MikroTik SxtSq stuck in boot loop
Sat Aug 06, 2022 8:46 pm
I just netinstall MikroTik SxrSq lite 5. Now device is not booting. Seems like it is stuck in boot loop. I tried reset button. But of no use. And now device is not even showing in netinstall or winbox.
holvoetn
Re: MikroTik SxtSq stuck in boot loop
Sun Aug 07, 2022 9:52 am
Which version of ROS did you try ?
Try netinstall again
- some prefer to use Windows, some prefer Linux (I'm in the second camp, I know of others having problems with Linux therefor only using WIndows. So try the other if one doesn't work for you).
- Make sure ALL network interface on your computer are DISABLED except for the ethernet interface used for netinstall
- Some have reported good results from putting a dumb switch in between their computer and device (it aids in making the ethernet connection look 'alive')
- press reset, power on the device but KEEP that reset button pressed until it appears in netinstall
It may take several attempts but it has to work.
Users browsing this forum: kokoboko, rextended and 95 guests
