dprnic
Command works from terminal but not as a script
Sun Aug 07, 2022 11:20 am
I have no experience with Mikrotik scripting.
This works from terminal but not as a script:
/system/ssh address=192.168.240.9 user=dprnic command="[/interface/wireguard/peers/add interface=wireguard_users public-key=\"X7ZcanAGeG+G7/rZWDV4RoZ8vohzaUW9pdqEfkdiFRw=\" allowed-address=192.168.254.130]"
More info:
I am sending SMS with this message:
:cmd M script add_wg_peer publickey="X7ZcanAGeG+G7/rZWDV4RoZ8vohzaUW9pdqEfkdiFRw=" ip=192.168.254.130
This is a script:
:global ip;
:global publickey;
/system/ssh address=192.168.240.9 user=dprnic command="/interface/wireguard/peers/add interface=wireguard_users public-key=\"$publickey\" allowed-address=$ip;";
Can anyone see what is the problem, please?
BartoszP
Re: Command works from terminal but not as a script
Sun Aug 07, 2022 12:15 pm
What is the value of $publickey in the script? Where do you set it?
When you send it from CLI then this value is explicity inserted into the command.
dprnic
Sun Aug 07, 2022 1:49 pm
The value of $publickey is:
I set it in SMS sending to router with LTE interface (sim card for 3G).
This part with setting the variable with SMS works.
When i put this in a script then it does not work:
I think i have problem with quotes. "
BartoszP
Sun Aug 07, 2022 2:12 pm
When the script is executed then in the line
system wants to substitute $ip and $publickey so it looks for their current value from the environment as they are the global vars
if the value is is not set then it is substituted as empty string. Try to debug those values with log lines as follow
:global ip;
:global publickey;
log warning  $ip
log warning $publickey
dprnic
Sun Aug 07, 2022 2:36 pm
The result is ok.
If i could see somehow what is the problem on the ssh remote router.
BartoszP
Sun Aug 07, 2022 2:44 pm
What the log on the remote device says when the command is executed remotely?
dprnic
Sun Aug 07, 2022 2:49 pm
I added topics script and wireguard.
No log.
Do i have to turn on some more topics?
BartoszP
Sun Aug 07, 2022 2:54 pm
Try to put publickey and ip directly into a script to execute exactly the same command as from CLI.
If it works then sth. is wrong with command send to remote host after substitution. If not then there is another problem? What one? We will see.
dprnic
Sun Aug 07, 2022 3:08 pm
After executing the command in terminal it says:
Welcome back!
And i can see that peer is created.
I delete it and try again from system script.
No log on both routers.
BartoszP
Sun Aug 07, 2022 3:18 pm
Once again: put that command which you execute in CLI VERBATIM into a script and then execute a script.
Be logged int remote device with Winbox watching the interface/list of interfaces for change during execution of command from script.
Even if there is no log info then you shoud see that something changes via Winbox ... even for a moment.
Maybe add ping command as ping count=100 ip.of.a.device.where.you.can.check.the.traffic to watch if there is a traffic comming from the other side.
Do not expect that anyone can figure whats going on both routers without access to them. You should be a little creative (every one should) when it comes to debugging. Sometimes "fast eyes" are the best tool :)
dprnic
Sun Aug 07, 2022 3:56 pm
Yes, i am doing that.
First in cli
Then in script
I tried something more simple also from cli and from script, but it also does not work from script and works from cli.
No extra log on local router
Remote router log only when i succesed with cli
dprnic
Re: Command works from terminal but not as a script  [SOLVED]
Mon Aug 08, 2022 9:06 am
I found the solution!
The problem is in command ssh.
/system/ssh... does not work in /system/script for remote router.
/system/ssh-exec... should be used instead.
BartoszP
Mon Aug 08, 2022 3:26 pm
Glad to read about successes :)
Users browsing this forum: eworm and 34 guests
