neruda3435
LNS on CHR (Performance Questing)
Mon Aug 08, 2022 10:34 am
With RouterOS, I'm planning multiple CHR setups to serve as LAC/LNS.
We have a lot of subscribers and active traffic.
I plan to divide the subscribers into CHR as access replicator and use CCR2216-1G-12XS-2XQ as Router.
Please suggest me a 10G or 40G or 100G side, CHR NIC that you can recommend directly, fully compatible with MikroTik and experienced.
Also, if there are tricks on the VM Esxi side, give them all.
I want to set up LNS with MikroTİK CHR and I serve 10000+ active subscribers.
neruda3435
Re: LNS on CHR (Performance Questing)
Mon Aug 08, 2022 8:33 pm
we can brainstorm
neruda3435
Tue Aug 09, 2022 9:26 am
I'm curious about your ideas and comments.
StubArea51
Trainer
Trainer
Tue Aug 09, 2022 4:18 pm
This may help to gauge hardware, resources and throughput although it doesn't specifically relate to LNS/LAC
MikroTik CHR – Breaking the 100G barrier
https://stubarea51.net/2021/12/13/mikro ... g-barrier/
Users browsing this forum: qatar2022 and 190 guests
