NTXsp
Port Forwarding with VRF Lite
Mon Aug 08, 2022 9:08 pm
Hi to all!!
I need to do a port forwarding to an internal server but I don't know how to do it (RouterOS 7.4)
This server is in other routing table (not in main table, due to VRF Lite configuration)
When I try to add a dst-nat to this server (in firewall->nat) I see "routing mark" and "connection mark" parameters but doesn't work.
(I already have routing and mangle rules for masquerade and internet access where I use connection mark and then specific the new-routing-mark and it works well)
Have I add mangle rules first and then dst-nat with routing mark parameter? Or is it not necessary? How I can do these rules?
Is there anything else to do afterwards?
Thanks and regards,
NTXsp
Re: Port Forwarding with VRF Lite
Wed Aug 10, 2022 5:14 pm
Hi!
It works when I add this routing rule: scr-address 0.0.0.0/0 dst-address 192.168.10.0/24 lookup vrf10
but this rule can accept connections from everywhere and I only want connections from internet (and not from other networks of other vrf's)
how can do more specific??
Thanks!!
sindy
Wed Aug 10, 2022 5:38 pm
Place
src-address=10.0.0.0/8 dst-address=192.168.10.0/24 action=drop
src-address=172.16.0.0/12 dst-address=192.168.10.0/24 action=drop
src-address=192.168.0.0/16 dst-address=192.168.10.0/24 action=drop
before your rule.
What do you mean by "VRF lite"? Manually configured routing marks and routing tables?
mrz
Wed Aug 10, 2022 5:42 pm
VRF lite is cisco terminology for VRF setups without MPLS.
NTXsp
Wed Aug 10, 2022 7:10 pm
Place
before your rule.
thank you, it's true.. it's as simple as drop all local networks before accept the rest.. :lol:
I'm going to try it tomorrow
Yes, I mean VRF Lite as VRF configuration without MPLS.
Regards!
Users browsing this forum: techcomtecnico and 116 guests
